Author Topic: My brat build Delima  (Read 771 times)
Offline dave
« on: April 27, 2015, 04:25:09 pm »
Well it's time to get back at the brat Build! It's a 74 750k,and I've sence installed a 92zx 7r front inverted suspension, but now not sure what to put for a swingarm on the back! I want to make it as easie as possible, and of course, cost efficiente... Any ideas on which swingarm will fit! Or what others have used/tryed..... Thnx
Re: My brat build Delima
« Reply #1 on: April 27, 2015, 04:59:47 pm »
Hi Dave, put this in the "SOHC/4 bikes" section mate, plenty of swing arm conversions there...
This is a good one but not cheap... I have one  ;)
http://forums.sohc4.net/index.php/topic,139903.0.html
The biggest problem with using other swingarms is the length, most are too long and negatively effect handling, I've had a couple cut down to suit but this requires extra expense and a competent welder.. Even using the Kawasaki triple clamps  throws the geometry at the front out, even more if you use the Kawasaki wheel...
