Author Topic: Frame corrosion, help !  (Read 1706 times)
Offline spitfire
« on: October 17, 2006, 10:50:46 AM »
I was just checking my frame over before I take it to be powder coated and spotted this on the right hand front down tube, looks like water has got in and corrosion has bulged out the outer tube (see photo). Has anyone one else had a similar problem and does anyone know of a cure ?
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline sparty
  • I just play one on TV
    • Gallery
Re: Frame corrosion, help !
« Reply #1 on: October 17, 2006, 12:02:08 PM »
My first thought is to have the fame "dip stripped" and then inspect the frame.  If the rusted areas are no longer welded together, you will have to refab those parts of the frame.  That is however, easier said than done without a frame jig.
Sparty
1972 CB750 K2 Cafe' Style
Offline crazypj
  • I'm brill, me
« Reply #2 on: October 17, 2006, 12:18:47 PM »
Its been in an accident at some time and the frame was straightened. Get all the paint off first and take a closer look. If it was rust bulging you would be able to flex the section with your fingers(just press on it) clean it out best you can , beat it back to shape and seam weld if your worried.  If you look at right side of picture you can see where the stiffening piece/steering head was plug welded into position ( the roundish area)
PJ
« Last Edit: October 17, 2006, 12:21:02 PM by crazypj »
Offline spitfire
« Reply #3 on: October 17, 2006, 12:37:40 PM »
I've owned it from new (1976 CB750F1) and it's never been dropped, have cleaned quite a bit of the rust out and the inner tube looks in good shape so will probably get them to blast it, hammer it back and then seam weld it, unless there are any better ideas out there ?
Thanks
Den
Wirral UK
Offline kghost
« Reply #4 on: October 17, 2006, 01:33:11 PM »
Tube and fabric aircraft use boiled linseed oil in the tubing.....I know you can get it at home depot.
Stranger in a strange land
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #5 on: October 17, 2006, 01:44:17 PM »
That split and plug weld look exactly like mine and I know it's not been wrecked either. I think beadblasting or dipping would address the problem.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline spitfire
« Reply #6 on: October 17, 2006, 02:04:56 PM »
Thanks for all the replies guys, guess I won't have to start searching on eBay for a replacement frame now ! Will be off to the paint shop tomorrow luckily they are also an engineering firm so should be able to do the repairs as well.
Thanks
Den
Wirral UK
