Author Topic: Whats your emulator setup?  (Read 1369 times)
Offline Puntas13
  • '73 cb500 '74 cb750 '09 Triumph Speed Triple
« on: April 29, 2015, 05:21:52 pm »
I'm rebuilding a set of 750 forks with straight rate springs and race tech emulators.
I'm about 155lbs and wondering what setup you dudes are using (oil wt, oil height, emulator preload, etc).
Ive gone over stueveone's post and i'm using it as a base line, and Ive already done the same set up on my 500 but wondering if it could be better.
Offline Roach Carver
Re: Whats your emulator setup?
« Reply #1 on: April 29, 2015, 05:34:31 pm »
« Reply #2 on: April 29, 2015, 06:24:46 pm »
CB750F3 forks on a 340lb CB550 with a 180lb rider.
15W fork oil
.85kg Racetech springs
63.8mm preload spacer
adjusted to 117mm fork travel (total F3 fork travel-132.7mm)
172mm oil height
emulator-3 turns
40 in/lb emulator springs
Offline JohnN
« Reply #3 on: April 29, 2015, 07:34:42 pm »
340lbs? I'm jealous!
Setup for my 405 lb 750 w/ 170 lb rider:
15w fork oil
.80 Racetech springs
70mm spacer (16mm  preload & 35mm sag)
140mm oil level (w/ Goldwing forks)
emulator- 4 turns (blue spring)
I've tried longer spacers with less sag but had problems with chatter, this setup works better so far.
John
« Last Edit: May 13, 2015, 07:16:55 am by JohnN »
CR750 replica
CB750K2
85 VF500F
66 CA160
67 CT90
2000 Triumph 955i
69 Triumph Bonneville
Offline Puntas13
« Reply #4 on: April 30, 2015, 10:30:35 am »
Thanks for the input. Ive had some chatter issues on my 500 but nothing too bad. For some reason i went with a 10w oil and           I set my oil height a little too high.
« Reply #5 on: April 30, 2015, 06:42:50 pm »
15W fork oil
172mm oil height
emulator-3 turns
How in God's name did you settle on 63.8mm spacers Brent? 63.9 were way to stiff and 63.7 way to soft? Sorry....I couldn't resist. ;D ;D
« Reply #6 on: April 30, 2015, 08:08:44 pm »
You know we don't measure with a yardstick here.  ;D
