Author Topic: CB550 DCC mini speedo and tach wiring help  (Read 3741 times)
Offline jayowen
« on: May 01, 2015, 04:07:22 PM »
I need help with the wiring of these guys. i have the speedo and tach. not sure what wires go to what in the headlight bucket on my CB550F. I have the wiring diagram for both the gauges and the bike but cant get it quite right. Has anyone done this that can help me out?? thanks
Offline riverfever
Re: CB550 DCC mini speedo and tach wiring help
« Reply #1 on: May 02, 2015, 07:17:23 AM »
Did you guys get this sorted out? I have the mini DCC tach and speedo and have the front end all apart right now.
Offline jayowen
« Reply #2 on: May 02, 2015, 10:54:09 AM »
still trying to put this all together. If you could post what your plugging each wire into id love that.
Offline riverfever
« Reply #3 on: May 02, 2015, 01:13:24 PM »
Stand by Jay. Everything is a mess at the front of my bike right now but I should have things going back together after I get these tapered head bearings in. Then I'll be able to see better where each wire goes and I'll let you know how I hooked it up. Are these the gauges?
Offline jayowen
« Reply #4 on: May 02, 2015, 03:31:09 PM »
sure are!!! i got the white and chrome ones.
Offline riverfever
« Reply #5 on: May 02, 2015, 07:29:41 PM »
OK Jay here goes...
The tach should have:
Black wire that ties into green for ground.
Red wire that ties into black for switched power.
Speedometer should have:
Red/black wire that ties into blue/red for oil pressure.
Red wire AND a green wire that ties into black for switched power.
Yellow/black, black, and a blue/black wires all tie into green for ground.
Orange wire ties into brown/white for speedo lights.
Blue wire goes to blue off the headlight for high beam led.
Green/black wire ties into green/red for neutral light.
Yellow is not used (I don't have turn sigs).
Let me know if you need anything Jay.
Offline jayowen
« Reply #6 on: May 04, 2015, 12:54:17 PM »
thanks a lot guys. got them all hooked up. She's running but waiting on headlight and tailight.
Offline DaveBarbier
« Reply #7 on: May 04, 2015, 06:28:20 PM »
I've got these same gauges and I noticed that the blue high beam LED is crazy bright. I added three 10k ohm resistors inline with this wire. I know that's a lot of resisting, but it's what was needed not to blind me.
1978 Honda CB550K
Offline riverfever
« Reply #8 on: May 04, 2015, 06:50:57 PM »
Yeah that blue led IS bright.
Offline jtran000
« Reply #9 on: June 01, 2015, 10:04:01 PM »
hi all,
i'm working on this right now also.  I just got the bullet connector and ratchet crimp from vintage connections and in process of putting them on.  Went thru like 10 already trying to fine tune.
I have a 77 cb550.  Anyone have pics?  I work better with pics :)
Offline jtran000
« Reply #10 on: June 01, 2015, 10:05:23 PM »
this is the same gauges i have :D
do i need to add bullets to the strip wires?  I also bought from vintage connections the triple sockets in case I need this.
thanks in advance,
John
« Last Edit: June 01, 2015, 10:26:54 PM by jtran000 »
Offline Hot500
« Reply #11 on: June 02, 2015, 02:33:57 AM »
If you intend to hook up indicators you will need to put a shunt in line on the yellow wire from the gauge. Because there is only one indicator wire for the gauge, both right and left side indicators must be joined to this one yellow wire.
That means if you switch on the right side indicators, your left side will flash as well.  So you must use a shunt which will only allow current to flow in one direction to the gauge, and not back out to the other side indicators.
CB500
SL350
KTM 990 Superduke
DR650 (sold)
DR250S (oldie but a goodie)
Offline jtran000
« Reply #12 on: June 02, 2015, 07:49:02 AM »
One of the reviews on DCC
"This is a great product. Good to slim down the front of your bike. A note about the turn signal indicator light and the fact that there is only one while many stock indicator panels have two lights. Some reviewers suggest using diodes to prevent your turn signals from turning into hazard lights (current runs through the indicator and to both turn signal circuits). I installed this on a Honda CB550K4 which has a turn signal buzzer and used it's circuit for the indicator. Not only does this result in the single indicator light behaving as expected, but also was a good excuse to get rid of the buzzer (which is pretty annoying). (Posted on 2/25/2015)"
