Author Topic: Rust Under the Fork Gaiters - Best Way to Address?  (Read 2475 times)
Offline Imago
  • 1978 CB750F
« on: May 03, 2015, 09:39:22 AM »
Well, I'm on the lookout for a 75/76 GL1000 front end to get the dual discs/wire wheels on my 1976 CB750K build, but in case I can't find the GL front end, what's the best way to deal with the inevitable rust under/above the front fork gaiters, particularly if you don't want to replace the gaiters?
Is re-chroming the only, (read: expensive) option?
« Last Edit: May 04, 2015, 08:00:11 AM by Imago »
Re: Rust Under the Fork Gators - Best Way to Address?
« Reply #1 on: May 03, 2015, 09:54:12 AM »
You can try to prevent it with silicon spray but if the gators are secured to the for ears and at the bottom by the rings, it's not so easy. It's easier if you use non stock gators that do not fasten to the rings so you can move them to clean the tubes.
Keeping the tubes under the fork ears completely rust free is not as easy.
« Last Edit: May 03, 2015, 09:57:59 AM by CB750 Cafe Racer Fan »
Offline CBDee
« Reply #2 on: May 03, 2015, 10:16:12 AM »
You could always paint the area beneath the gaiters to try to keep rust away, but the gaiters will cover any problems you might come across. Do not get  aftermarket gaiters because they don't last and will fail within a couple of years. Get the Honda gaiters and get better quality gaiters;D ;D ;D
Sent from my Old & Busted PC using Myindexfingers
Offline MickB
« Reply #3 on: May 03, 2015, 11:29:54 AM »
Try rubbing the rust down and use POR15's Marine Clean followed by Metal Ready then apply POR paint and you'll get on top of the rust problem, done correctly they reckon 45 years no rust, finally cover with new gaiters.
Offline wowbagger
  • Not much of an
« Reply #4 on: May 04, 2015, 07:00:16 AM »
I had rust on the upper section of my forks above the area the seal travels across. I ended up bead blasting just the upper half and then powder coating them with a chrome powder. It's not an exact match but the gaiters cover the transition area so it's not noticeable:
Offline Imago
  • 1978 CB750F
« Reply #5 on: May 04, 2015, 07:25:58 AM »
Nice! Did you polish the lowers yourself?
We're powder coating the frame black...how would that look on the upper half above the seal area? Cheaper, no doubt, than a re-chrome.
« Last Edit: May 04, 2015, 08:04:49 AM by Imago »
« Reply #6 on: May 04, 2015, 07:57:15 AM »
Gaiters damnit
Offline wowbagger
  • Not much of an
Re: Rust Under the Fork Gaiters - Best Way to Address?
« Reply #7 on: May 04, 2015, 08:01:02 AM »
Yes, fork gators are something entirely different:
Offline Imago
  • 1978 CB750F
« Reply #8 on: May 04, 2015, 08:03:37 AM »
"Gaiters"... got it... finally.
It's like having my proofreading, grammar correcting wife here...
« Reply #9 on: May 04, 2015, 02:08:01 PM »
That chopper reminds me of the video of the guy in the Predator suit riding a chopper.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #10 on: May 05, 2015, 08:33:38 AM »
You could clean with acetone, lock the rust with a rust reformer and then spray the rattle-can plastic cote from Rustoleum or whomever and lock the surface.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
« Reply #11 on: May 05, 2015, 10:21:33 AM »
Is that a Florida Gaiter?
Amazing what hides behind those. I prefer the dust seals on my F. Nothing lurking creating problems like that. If you're going to retain gaiters then blast them, use some rust inhibitor which will turn it black and hope the corrosion doesn't extend past the oil seals.
Or new fork tubes........ and use the dust seals instead to prevent that from happening again. I think ?? they will fit??
Offline Maurice
« Reply #12 on: May 05, 2015, 10:23:23 AM »
Somehow, I don't mind never seeing that video.
« Reply #13 on: May 05, 2015, 10:30:18 AM »
I don't think there is any foolproof way of avoiding oxidation of the fork tubes under the stock fork ears.  The rubber cushions help, but the fork ears themselves have holes exposing them to moisture (not too much).  I think you might be able to spray some silicon spray in the crevices to help fight oxidation.
