Author Topic: Clear coating polished alluminum?  (Read 1061 times)
Offline jamesbekman
« on: May 04, 2015, 12:16:49 PM »
Hi Everyone,
Im buffing my wheel hubs after hand sanding them and also some of the side covers for the engine...  Am I able to clear coat the hubs/covers or will it not stick to the polished surface?
James
Offline MickB
« Reply #1 on: May 04, 2015, 12:18:36 PM »
What ever you do don't use the POR clear as you'll lose the beautiful shine. From experience, I picked it all off and re polished.
« Last Edit: May 04, 2015, 02:28:53 PM by MickB »
Re: Clear coating polished alluminum?
« Reply #2 on: May 04, 2015, 02:26:34 PM »
Get them clear powder coated... ;)
Offline 01Thomas
« Reply #3 on: May 04, 2015, 02:32:43 PM »
You can clear coat them but eventually (sooner rather than later ) the coating will yellow. I've found that polished ally holds it's shine quite well, to the point than a once-a-month wipe-down is all that's required.
~T
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
« Reply #4 on: May 04, 2015, 03:04:34 PM »
Not all clear coatings yellow Thomas, most are UV stabilized these days.  ;)
« Reply #5 on: May 04, 2015, 04:45:53 PM »
Most clear coats are UV stabilized (unlike the original durable factory clear coat).  Clear powdercoating offers much more durability and resistance to chemicals as well.
Offline jamesbekman
« Reply #6 on: May 05, 2015, 07:32:48 AM »
Ok, Im more curious about adhesion problems due to it being a polished surface.  If you have done it before, besides yellowing, were there any problems?
Or should I just get them buffed out, re spoke the wheels and just try and somehow keep up on cleaning the hubs.
-James
« Reply #7 on: May 05, 2015, 07:56:53 AM »
No problems with adhesion for PC clear coat.
