Author Topic: PD carb bracket help  (Read 1042 times)
Offline futility
« on: May 05, 2015, 04:15:42 PM »
So long story short, I saw the screw holding this thing on and decided it should come off. Upon picking up my screwdriver (a good JIS one none the less) it immediately went round-shaped. Thinking it may be loctited, I gave it some heat then turned to a screw extractor and the head immediately popped off leaving whatever was left in the hole. I then took the extractor to that and promptly destroyed the entire hole. Here is the aftermath:
In that entire process the screw never let up at all. At this point I cannot even tell if there's anything left of the screw remaining in there, and the hole is off center which would make tapping it a pain. Anyone ever tried to get this thing off with any success, or is it best left on for all eternity? Should I just cut my losses and buy a new #2 carb?
'78 CB750F3, '09 DR650, '09 CBR600RR
Re: PD carb bracket help
« Reply #1 on: May 05, 2015, 04:25:25 PM »
Put down the tools and contact forum member harisuluv.  He's probably got what u need.
Offline harisuluv
« Reply #2 on: May 05, 2015, 05:02:06 PM »
Pretty common, that one can be really tight.
If you're confident with your ability to drill it out or tap it/helicoil/something it's not real vital that it is a perfect machining job.
If not I do have some bodies (#2).  I keep a pretty good selection around that are already cleaned and essentially ready to go.
Offline futility
« Reply #3 on: May 05, 2015, 05:13:46 PM »
Thanks for the replies. How much are the bodies? I think I'll have a go at tapping this one but in the very likely event I destroy it I'll be in the market for a replacement.
Offline harisuluv
« Reply #4 on: May 05, 2015, 11:43:51 PM »
It depends on condition.  Average useable with some cosmetic flaws, maybe minor pitting, around $25 shipped.  A pristine body with almost no corrosion/pitting, no damage, never been pried off and messed up, good plating (if applicable) low mileage, $50 shipped.
spares are already soda blasted.
Offline futility
« Reply #5 on: May 06, 2015, 06:46:11 AM »
Mind sending me a picture of something in average/a little above average condition? I don't mean to be a pain but I'd like something that somewhat matches the condition of the other three carbs, and those are definitely not pristine. Thanks!
