Author Topic: Slow crank.  (Read 10970 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Slow crank.
« on: May 06, 2015, 03:54:18 PM »
After market start button, fresh battery.
Slow crank with the button. Fast as hell when i jump solenoid.
Button or solenoid?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #1 on: May 06, 2015, 05:23:05 PM »
Wire size? Not wired properly?
Gus, Austin, MN.
Offline hsas.69
Re: Slow crank.
« Reply #2 on: May 06, 2015, 06:09:32 PM »
Why did you replace the button to begin with? The button shouldn't really affect the cranking speed too much cause its just the control to the solenoid which is a relay. The main power to the starter never goes through the switch, just fromvthw battery through the solenoid and to the starter.
78 CB750 F3
78 CB550 K4
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #3 on: May 06, 2015, 06:10:26 PM »
Came that way. Handlebar button missing. Looks like button is wired to each post of sol.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #4 on: May 06, 2015, 09:03:22 PM »
Here's what i got. Button has 2 wires. Right now has one wire on each solenoid post.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #5 on: May 06, 2015, 09:19:44 PM »
Works better when i hook the wire that was on the Batt post directly to batt and pushed button
Gus, Austin, MN.
Offline Badluckhonda
Re: Slow crank.
« Reply #6 on: May 06, 2015, 09:45:58 PM »
Best way way to wires solenoid from my experience is by giving constant power to it. The button provides the ground when pushed down and completes the circuit. If you wired it thee other way it'd probably burn the wire from the high amperage
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #7 on: May 06, 2015, 09:51:04 PM »
So what post should i be on? Post with starter wire through button then ground?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #8 on: May 06, 2015, 09:55:35 PM »
When i hook up wires this way, nothin when i push
Gus, Austin, MN.
Re: Slow crank.
« Reply #9 on: May 06, 2015, 10:17:25 PM »
Don't really understand what you mean but if your switch has two wires do this. Make sure your selenoid getting 12volts as soon as you turn on the key. it should have two wires beside the lager wires that go to battery and starter. Wire one of these with 12volts after the ignition switch.
 So then on your switch/ starter button, run a good ground to one wires then the other wire to the ground on the solenoid. So now when you push the button it will ground out the selenoid
« Last Edit: May 06, 2015, 10:20:42 PM by Badluckhonda »
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #10 on: May 07, 2015, 04:18:58 AM »
Where do i hook up the ground on the solenoid?
Gus, Austin, MN.
Offline Bodi
Re: Slow crank.
« Reply #11 on: May 07, 2015, 05:03:03 AM »
This problem is inside the solenoid, not with the button or its wiring. Since crossing the studs gives good cranking, clearly the solenoid's internal high current contacts are not closing properly: the poor connection will be producing a lot of heat whenever you use it this way.
Remove the solenoid, disassemble the stud end, file clean flat contact surfaces on the stud contacts and switching bar. Clean the moving parts as well as you can. Reassemble and it should be OK. Replace it if it's badly burnt or seized mechanically.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #12 on: May 07, 2015, 05:10:50 AM »
I can do that. Question still remains...which post should i ground?
Gus, Austin, MN.
Re: Slow crank.
« Reply #13 on: May 07, 2015, 07:18:22 AM »
What color are the tw smaller wires on the selenoid ? If it oem the green one. Which is ground on these old honda
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #14 on: May 07, 2015, 07:33:48 AM »
So hook it up to that?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #15 on: May 07, 2015, 07:34:00 AM »
And the other to the starter post?
Gus, Austin, MN.
Re: Slow crank.
« Reply #16 on: May 07, 2015, 10:15:35 AM »
Ok one more time. There's two large wires one the solenoid  one to battery positive thee other to the starter.
Which leaves the two smaller wires on the solenoid. One gets power after the ignition switch. And thee other goes to the starter button, which ground out the solenoid complets circuit
That's the way it was probably already hooked up. You just need clean up the solenoid
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #17 on: May 07, 2015, 11:46:46 AM »
Gotcha. So find where the green wire ended up after the PO hack job and hook it to the button, then to a ground
Gus, Austin, MN.
Re: Slow crank.
« Reply #18 on: May 07, 2015, 11:53:23 AM »
If it's a factory start button it makes the ground when you push it.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #20 on: May 07, 2015, 06:38:50 PM »
Heres what i found today. Yellow/red and green/red. If i look correctly at the diagram, yellow red should be power all time, green red ground (through switch). My yellow/red was capped in the harness. Green red looks to be plugged into a ground connector.
Should i wire yellow red to a power after ignition, then green red to my switch and frame?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #21 on: May 07, 2015, 06:50:33 PM »
Check that, opposite. Yellow/red to button, green red to power.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #22 on: May 07, 2015, 07:47:50 PM »
Yellow/Red comes form the START button and delivers 12v to the solenoid. The Green/Red comes from the factory NEUTRAL switch (providing the ground when in Neutral). The 2 large studs are wired to the battery POS and the other to the starter motor.
Easy.
Im pretty sure this goes against what everyone else is saying.
Here's what i tried tonight. Hooked green red to direct power and used button for a ground, nothing. Green red to power and yellow red to frame...nothing. green red plugged into harness, yellow red to ground thru button nothing. 12v through button to yellow red. Nothing.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #23 on: May 07, 2015, 07:52:11 PM »
Still can jump sol and get great spark
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Slow crank.
« Reply #24 on: May 07, 2015, 07:58:07 PM »
How does the sol get power then shouldn't it in theory work then with IGNITION off?
Gus, Austin, MN.
