Author Topic: Need a pic please of where this thick black wire in the pic goes? Honda CB 550  (Read 807 times)
Offline Way Way norcal
I am winding down on a long build on a CB 550.  Can someone tell me where this wire goes??
Offline jamesbekman
Goes to the starter solenoid.
+1, starter solenoid
Offline helltaco
The starter solenoid is the cylinder just left and above center in this pic. You can see the thick black starter wire snake up the left side between the frame and the electrical panel and to the terminal on the solenoid. The other terminal has a thick wire to the + battery terminal. The solenoid is a big switch that connects the battery to the starter.
73 CB500, 75 CB550, 2014 Ural, 99 Buell short chop, 78 Triumph Bonneville basket case.
that would make perfect sense why I can't find where it goes.  All that stuff went in the scrap heapl
i decided to pull my electric start and eliminate that wire and use the kick start only.
thanks for the pic and info
« Last Edit: May 08, 2015, 12:40:52 PM by Way Way norcal »
