That can of Berryman's carb cleaner is a nice place to soak for the evening
But are there some part of the carb you just don't want to put in there - like the fuel flow valve (with the rubber tip of course)?
Specifically, to narrow this down a bit, I'm thinking along the lines of the float bowl - without gasket. I'm assuming the jets can go in. I just wasn't sure if there were coatings on the carb body parts that you would not want to soak. Rubber will dissolve of course I know that much.
