Author Topic: would you put in a big bore kit and a hot cam if you had the chance?  (Read 13297 times)
Offline b5rider
Re: would you put in a big bore kit and a hot cam if you had the chance?
« Reply #75 on: May 30, 2015, 07:21:45 AM »
I'll try to have a video up today
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline Tews19
  • I am no
« Reply #76 on: May 30, 2015, 07:30:24 AM »
Awesome! Is it tuned? If so what's your carb settings?
1970 Honda CB750 survivor.
Offline b5rider
« Reply #77 on: May 30, 2015, 07:33:09 AM »
I'll ask today.  Andrew pulled the plugs after the test drive and he said it is perfect
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline b5rider
« Reply #78 on: June 01, 2015, 12:57:05 PM »
My mechanic stated the 603cc kit with the 650 cam in my 550 pulls as hard as the 650 in his shop.  The midrange power is definitely more noticeable. It's not a subtle cruiser anymore... Until I put the sidecar back on.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline Tews19
  • I am no
« Reply #79 on: June 01, 2015, 01:10:56 PM »
Awesome. Were you able to get the Carb settings?
Offline b5rider
« Reply #80 on: June 01, 2015, 01:20:46 PM »
As soon as I get the idle to not hang
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline Tews19
  • I am no
« Reply #81 on: June 01, 2015, 02:32:57 PM »
Hanging idle? Wd-40 spray the boots. See if it increases. If it does you have a leak.
Offline b5rider
« Reply #82 on: June 01, 2015, 02:36:10 PM »
Tried that.  No change.  I'll post a dedicated thread soon with all the particulars
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline b5rider
« Reply #83 on: June 01, 2015, 03:19:27 PM »
I've only been on 2 550s. One had 24k miles and the other was in need of a rebuild,  so my review is very subjective
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline b5rider
« Reply #84 on: January 06, 2016, 07:23:54 AM »
Just a short update on the build.
I replaced the carbs with some older ones (with 105 mains) because the PD carbs were not able to be tuned to my liking. The older carbs worked great out of the box.
I pulled the plugs after some 20 miles, and they all look good; no soot or white chalk, just some nice tan color
I broke the engine in with the sidecar in place because I let my M1 permit lapse and you don't need a motorcycle license to ride a 3-wheeled vehicle in California.
The bike pulls hard in the midrange and has no flat spots during acceleration.
Only issue I've noticed is it gets very hot during freeway rides. I think it's a combination of the big bore kit and the extra load from the sidecar.
I will add an oil cooler with a built-in thermostat as soon as I can find a location for it as the sidecar mounts are in the way.
I have had a few issues with oil leaks from the tach gear, rocker covers, oil pan, and shifter shaft. Most of those have been resolved except the tach gear (started another thread)
Anyhow, I am really enjoying the extra power and would recommend the upgrade to anyone with a 550.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline flatlander
« Reply #85 on: January 06, 2016, 08:03:18 AM »
are you going to dyno it? if so, please post results.
Offline b5rider
« Reply #86 on: January 06, 2016, 08:26:57 AM »
Unfortunately, I don't have any free access to a dyno, so I'm using my carefully calibrated butt dyno.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
« Reply #87 on: January 06, 2016, 12:57:51 PM »
If it's getting hot you may want to take the time to increase your jetting and see what the plugs look like and what the AnalDyno says.
« Reply #88 on: January 06, 2016, 01:55:16 PM »
+1
I had similar experience with my bike. I could do richer and solved a heating engine and got better throttle responce too.
EDIT: Check pilot jets by only drive in lower speed, low throttle lift. It is easy to miss lean pilot jet if mostly driving full throttle as the dyno guys usually do.
« Last Edit: January 06, 2016, 02:00:05 PM by PeWe »
Offline b5rider
« Reply #89 on: January 06, 2016, 02:43:45 PM »
Thanks.  Most,  if not all,  of my driving is below WOT
Sent from my SAMSUNG-SM-N920A using Tapatalk
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
