Author Topic: Re: Rickman restoration  (Read 18895 times)
Offline hagar24
« Reply #100 on: February 24, 2017, 10:04:01 PM »
Beautiful work on that swingarm!
Thank you sir
Offline slikwilli420
  • Master of Disaster
« Reply #101 on: February 25, 2017, 05:57:07 AM »
Hard to see all o what is there. I see foot pegs/levers, the inner fender and some electrics. Anything else. I'd be in for the Rickman pieces as long as they aren't damaged.
You are looking at right and left foot pegs, brake pedal, wiring harness and inner fender
PM sent.
Re: Re: Rickman restoration
« Reply #102 on: February 25, 2017, 08:41:39 AM »
Nice project.   I've been to Jamaica a couple times (Montego Bay, Ocho Rios & Negril) beautiful country.
Where are you?
Offline hagar24
« Reply #103 on: February 25, 2017, 11:24:10 AM »
Where are you?
I am in Kingston St. Andrew
Offline hagar24
« Reply #104 on: February 25, 2017, 03:27:45 PM »
So I took apart the 1100 Katana engine today and this is what I found,someone installed new piston and rings, but did not do any work on the head,engine was sitting for a while and had no compression so thats why I took it apart, 3 cylinders had frozen rings, and then I found this rocker that they adjusted to tight and the cam wore down the rocker, do you think I can repair it for further use?
So I put the bottom half of the motor in the frame,I now need to get the chain running in a straight line with the 6" RC wheel sprocket, I might have to flatten the part of the frame where the chain runs, the chain is sitting on the frame behind the swing arm making a curve in the chain, already flip the rear sprocket, did't help much
So I finally got the bike back today, came home and set it up with the front and rear wheel and this is what it looks like, will have better pictures when it stops raining.
Setting up the motor
Lining up the chain
Fitting header
Header fitted
Oil cooler installed
« Last Edit: April 07, 2017, 08:36:38 PM by hagar24 »
Offline hagar24
« Reply #105 on: May 15, 2017, 12:54:40 PM »
Ok, so after a little lull in the activevity on the Beast this is where it is.
Offline hagar24
« Reply #106 on: April 27, 2018, 12:58:52 PM »
After ooh so long I am back with update on the Rickman project, M unit
for the electronics and the paint tank after repair.
« Last Edit: April 27, 2018, 01:17:14 PM by hagar24 »
« Reply #107 on: April 27, 2018, 03:22:30 PM »
Color is pure 70's retro. I love it. Really excited to see where this goes.
Offline hagar24
« Reply #108 on: April 27, 2018, 03:27:04 PM »
I am going to build the under seat pans for the wires next week and start her up, I will make a video  for the start up and hope I can post it here, bullhead and bracket.
Under seat pans for electrics.
Installed
« Last Edit: May 08, 2018, 09:17:06 PM by hagar24 »
