Author Topic: CB750 clutch question - lifter plate "button"  (Read 1813 times)
Offline Eydugstr
« on: May 12, 2015, 02:07:54 PM »
Working on a '72 CB750 clutch, and noticed that at some point Honda changed/superceded the clutch lifter "button" (22846-300-000 to 22846-300-010, the piece that goes in the center of the lifter plate bearing) and added a "tip" in the center (the earlier ones just being a flat top).  It looks like it'd go into the center of the clutch mainshaft (where the oil would be coming out.)  Does anyone know why? Was this Honda's attempt at getting more oil into the clutch?
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 clutch question - lifter plate "button"
« Reply #1 on: October 06, 2016, 08:07:37 PM »
I'd like to know the answer too.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline disco
« Reply #2 on: October 06, 2016, 10:44:29 PM »
Not 100% sure, but I think the purpose may be to maintain alignment of the lifter plate. This may have been part of the effort to quieten the clutch down?
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Dream750
« Reply #3 on: October 09, 2016, 06:09:35 AM »
The reference I’ve seen for clutch lifter: 22846-300-010 is used when upgrading the early 750 clutches to the late factory style.
Apologies for the poor photo quality as it’s a copy of a copy.
« Reply #4 on: October 09, 2016, 07:59:25 PM »
I looked at my K7 part, from engine # 2704603, and it doesn't have the "tip"?
Offline disco
« Reply #5 on: October 09, 2016, 11:10:52 PM »
Hi Scottly,
Is there a possibility the clutch has been changed? Has your K7 got the larger plate on the outside with the slant cut corks? Does it also have the 'double steel friction plate'? If not, then likely clutch has been changed/modified some time during its life.
« Reply #6 on: October 10, 2016, 12:05:39 PM »
Disco, my K7 motor does have the double steel plate, the larger outside plate, and the deeper clutch basket. I think I was the first person to open it up after leaving the factory. ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: October 10, 2016, 02:03:17 PM »
All of my K8's (6) have the smooth button as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
