Author Topic: Logan's Reward - CB500 and CB550 Cafe Projects  (Read 75051 times)
Offline Restoration Fan
  • My wife will never call me
Re: Logan's Reward - CB500 and CB550 Cafe Projects
« Reply #150 on: August 01, 2015, 12:31:23 PM »
So I finally had some time to do a bit of work on the bikes this weekend.
On the 500, I put some knee indentations into the tank and then applied a coat of Bondo to smooth it out.  After sanding, there are a couple of low spots on each side so it'll need another skim coat to finish it out.  There's vinegar soaking on the inside of the tank right now so I'll probably get to that on Monday for the second coat, after the vinegar has had a chance to clean out some of the flash rust on the interior.
« Reply #151 on: August 01, 2015, 12:42:52 PM »
But on the 550, I was able to mock up the rear and front ends.  Here's what I found with the CBR front & rear ends, in case someone else wants to do this.
On the front end, All Ballz makes a CBR to 550 conversion bearing so I THINK I will be able to just plug and play the entire CBR1000RR front end into the 550 neck, using the top & bottom conversion bearing sets.  Those have been ordered so I won't know for sure until they arrive.
On the rear end, here are the measurements I found with respect to the CBR600RR swing arm vs the 550 swing arm.  Measuring from the swing arm bolt to the front and rear of the axle pass-through hole on the 550 swing arm measures 17 1/8" to the front of the hole and 19" to the rear of the hole.  Also, the 550 swingarm bolt is a 14mm bolt.
The CBR swingarm bolt is a 17mm thickness bolt so it won't fit inside the factory holes in the frame. BUT, the CBR bolt uses a spacer rod that is about 80% of the width of the swingarm and has 2 other spacers as well.  I removed those spacers and slid the standard 550's 14mm swingarm bolt through those spacers and then I was able to mount the CBR swing arm onto the frame for mock-up purposes.  That results in a measurement of 19 1/2" to the front of the axle pass-through hole and 21 3/4" to the rear of that hole.  The spacers that came with the CBR rear end actually make the tire seem like it's going to work.
I work at a large engineering firm, so I'm going to have some of my engineer buddies help me determine if the 14mm bolt, wrapped by the spacer would be strong enough to support the CBR's added few inches of length.  If it does, I'll probably have a new spacer milled that takes up most of that extra 3mm of diameter so it's more of a snug fit around the 14mm bolt.  If not, I'll have a machine shop widen the 14mm holes out to accommodate the 17mm bolt.
However, I'm less enthused about the mono-shock after mocking it up onto the swing-arm.  I'm not sure it's going to work on the smaller 550 frame vs the CBR frame.  I would definitely have to have something fab'ed up to handle the shock mount onto the frame anyway but I moved it around in a few different areas and I'm just not convinced it's going to work for sure right now.
« Last Edit: August 01, 2015, 12:45:06 PM by Restoration Fan »
« Reply #152 on: August 01, 2015, 11:12:53 PM »
It is too long and sourcing a shorter one just runs into all kinds of variables to consider.
I think that the dual shocks are classic and much easier to tune as well as providing a wealth of choices.
I wondered as I read the thread why no one suggested the All Balls kit if you had the space in the steering neck.
Just lots of suggestions to spend lots of money.
Some of the things your son would like is the added legs the 650 cam adds to the 550 if you can find one for a reasonable price.  Check out your cam cover for any eccentric wearing of the rocker shafts.  This was a common problem the 77-78 pinned longer rocker shafts fixed.
A good upright position really is good for longer distance and comfort. Less weight on the wrists to lessen issues with carpal tunnel or tendonitis as well which the leaning forward position can irritate and contribute to some issues later. Some people don't have problems, but,  if you develop it you really don't want your bike to make it worse.
Look at a Buell headlight bucket that's steel, large enough for a good motorcycle H4 7" headlamp.  Even the Buell Blast had a decent bucket.  FunJimmy's Cafe Interceptor used one.
Added thing is they are inexpensive.  Careful buying master cylinder as there are fakes out there.  Sometimes buying a used one and rebuilding it can be a good way to go.
If you don't have the cbr MC.
Good luck with the 500 build.  May wish to consider remote reservoir MC for it with dual discs.
Electronic tach eliminates several issues and cleans up cables...
not sure that's a plan for the 500, but would be for 550. Unless you are going with the aftermarket speedo cluster for it as well.
« Reply #153 on: August 02, 2015, 05:02:38 AM »
Thanks, RAF for all the suggestions.
The CBR front end is a working front end that comes complete with the MC already on it and working, for that matter, it works quite well.  I'm thinking that it really will be as simple as the All Ballz conversion kit to make it work.  The extra 1/4" difference in height may mean that I have to cut off that much from the top of the tube and extend the threads down an extra 1/4" but that seems a much easier solution than changing out tower rods.
The more I looked at the back end yesterday, the quicker I came to the conclusion that the mono-shock from the CBR just wasn't going to be an option.  First, I didn't really care for the look so much but mainly the height of it was just untenable.  So I'll have to figure out a way to make the dual shocks work with that aluminum swingarm.
On the 500, I'm going to try and stay with the stock single disc up front so that I don't have to dump much money into it.  It's just going to be a "learn to ride" bike for him to get some early seat time after he takes his MSF class and then we're going to sell it.  It's also going to be my experimentation bike that I'll use for determining how we really want to do the seat pan, battery tray and wiring.  If we don't get it perfect on the 500, we can use the lessons learned on Logan's 550.
Offline rb550four
« Reply #154 on: August 02, 2015, 02:28:45 PM »
I don't know much about this conversion ,  would it be possible to have 1/4 spacer made to take up the slack and leave the
tree it's original size? Maybe a stupid idea , just throwing it out there.
« Reply #155 on: August 02, 2015, 04:01:49 PM »
rb,
It looks like it's just as simple as ordering the All Balls conversion kit.  Essentially, they just provide a different sized race and ball bearings that allow you to use the existing CBR1000RR tree, including the stem and it makes it fit within the frame neck you have.  On the All Balls site, there's a Fork Conversions menu link on the top of the page.  You put in the frame and then choose the new triple tree stem.  It then gives you the All Balls top and bottom bearings kit #'s.
« Reply #156 on: August 08, 2015, 03:53:23 PM »
If you have a 1/4 inch of the stem unthreaded above the top tree then a bearing sield and spacer to properly torque the stem and load the bearings is needed. The nut won't cover the races most likely,  so a cover is needed.
So, have something turned out of aluminum,  check the fit and then have it anodized.  Have two made since it isn't going to cost a lot more for the 2nd. Then you can have a spare for another build or one to sell.
RB's idea is a good one, easier and likely cheaper and you don't have to have the triple tree's hardened stem cut additional threads.
« Reply #157 on: August 12, 2015, 06:43:26 PM »
OK, so I spoke with a civil engineer and a mechanical engineer.   I'll try to summarize what they said regarding the swing arm and using the 14mm bolt vs the 17mm bolt.
Both said that if I were going to use a mono-shock solution that they would recommend the 17mm bolt.  They both also said that, by going with a dual shock solution with the CBR swingarm, the 14mm would probably be fine.  They explained that the greatest concern with the bolt would be "shear force" applied downward on the inside of the frame where the swingarm and the frame meet on both sides.  And they also emphasized that the engineers for Honda chose a 17mm bolt for a reason...although they concede that the mono-shock would certainly be a factor in that decision.
So, in essence, I have decided to have the 14mm holes in the frame drilled out to accommodate the 17mm bolt that came with the CBR rear end.  All three of us (the engineers and me) all believe that the 17mm bolt gives the largest safety margin to ensure that there's no issue with tensile strength and shear force.
« Last Edit: August 12, 2015, 06:47:23 PM by Restoration Fan »
« Reply #158 on: August 12, 2015, 09:09:21 PM »
Good decision.  Why leave it to chance?
« Reply #159 on: August 12, 2015, 09:41:49 PM »
I am not a mechanical engineer but the engineering degree I have and materials class and metals study taught me enough to know that you would be fine with the 14, but you are going to have extra protection from the 17. The issue is you are strengthening the bolt but haven't strengthened the frame to handle the load the of the rear arm's increased strength. So, without adding gussets and crossbrace you are not able to use the improvement. That's my thoughts on it.
« Reply #160 on: August 12, 2015, 09:53:13 PM »
Oops, I left out that part.  The civil engineer also suggested that I have them area around where the 17mm hole is created strengthened...most likely by having extra supporting metal welded around the new hole to help provide support stability to lessen the chances of the frame cracking or splitting there.
« Reply #161 on: August 15, 2015, 05:06:14 PM »
I love days like today.  I had all day to ride and work on bikes.
I got the idle air control valve replaced and the check engine light extinguished on my Jeep.
Then, I went and bought 5 gallons of Cleaning Strength White Vinegar and put as much of it as I could into the 500 tank.  After soaking most of the day, I just cleaned out the vinegar and washed out the tank....purrty and clean on the inside now.  So, I put some Marvel Mystery Oil in the tank, put the gas cap on and sloshed it around so that it coated all of the interior of the tank...hopefully, that will stop any flash rust until I can get it painted.  Once I do that, I'll put some gas in it to stop the rust.
I also put another skim layer of Bondo on that tank, as well as the extra 750 tank I have for Stella.  This afternoon, I sanded both of those down and they're ready for primer.  Once I've had a chance to watch a bit of NFL pre-season football tonight, I'll go lay down a coat of primer on both tanks.
I also got the races removed from both the 500 and the 550 frames.  Then I called the Cherokee County Sheriff's office and had an officer come out and perform the VIN verification checks on both frames.  It was a lady deputy and she looked at the frames, the engines and all of the parts stacked up around my work room and said, "So all of these are going to someday be 2 motorcycles?" and smiled.  I told her, "Yeah, I could make both of them into rollers in a matter of about 10 minutes and you'd get the idea of what they will begin to look like."  So she said, "why haven't you already done that then?"
To which I replied, "Because those parts were purchased separately from those frames.  If either of those frames came back as having issues, then all I lose is the frame.  If I have the parts in the frame, then you have to seize the frame and I have to argue with you about whether I get to keep the parts or not....this way, there's no doubt."  She laughed and said, "Great point.  But both of them came back clean.  You're good to go."
Finally, I got some more cleaning done on the 500 motor and got it closer to being ready for paint.  I figure I have another hour or two of prep work to get it perfect before I lay the primer coat down on it as well.
Also, did a bit of work on Stella today and then took her for about a 15 minute ride just to make sure she's running well.  She performed beautifully and I brought her home with a great big smile on my face.  Tomorrow morning, I'm going to take her out a bit longer ride.
Offline AintNoEasyWay
« Reply #162 on: August 16, 2015, 05:05:51 AM »
Great update. Happy to hear Stella is able to get some attention now too. Safe riding today!
« Reply #163 on: August 16, 2015, 06:47:27 AM »
Only 15'? Shame on you! She deserves at least an hour after all her fuss during assembly. Signs of a bike that wants to be ridden  :D
LOL, well I brought her home to adjust the clutch because it still didn't feel quite right.  But I made up for it this morning and took her out for about a 20 mile ride.  That's the longest I have gone on her so far and I'm going to do the same again this evening.  After which, I will have about 60 miles on her and I'm going to do an oil change and move to Bel-Ray 20W50 oil.  (*hoping I can get yet another oil debate going *)
I did get the first coats of primer on the tanks last night as well.  There really is no substitute for a layer of white or gray primer to point out the imperfections for you.  I'm about to take the boys out for morning brunch and then come home to do some more sanding, filler work and primer yet again.
All Balls bearings scheduled to arrive tomorrow so if I can get the tank painted today as well, then we should have a roller with an engine in it by Tuesday or Wednesday.
« Last Edit: August 16, 2015, 08:29:31 AM by Restoration Fan »
Offline knottedknickers
« Reply #164 on: August 16, 2015, 08:38:14 AM »
I tried stirring the 'oil can' a few days ago with a discussion of Lucas 'Hot Rod & Classic Car' oil. Apparently, it's got 2100 ppm zinc in it. I'm just wondering if that's too much... Do you know how much the Bel-Ray has?
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
« Reply #165 on: August 16, 2015, 08:47:14 AM »
According to this study, it has 1235 ppm.  Here's a pretty interesting paper that does a study on American motorcycle oils.  They test viscosity, zinc and/or moly ppm, etc.  They have a Lucas Oil High Performance Motorcycle oil in the test but not the one for Hot Rod & Classic Cars.  Apparently the 2100 would be at the upper end of the spectrum but there are a few in the study with higher ppm's.
http://americasoil.biz/files/g2156_A_study_of_Motorcycle_Oils.pdf
« Reply #166 on: August 16, 2015, 08:53:16 AM »
Mist it with guide coat, Ron. That's the cats pajamas for perfect surfacing.
Cal,
What brand of guide coat do you use?  Is it a Bondo product?  And where do you buy it?
« Reply #167 on: August 23, 2015, 02:16:09 PM »
Made a lot of progress on the 500 this weekend.  Engine is painted and back in the frame.  Swingarm painted and back on and triple tree is painted.  All Ball bearings are all ready but I'm waiting on Bill Benton to back from Rockingham where he's busy kicking a bit of drag racing butt on his 750.  Once he gets back and I can borrow his tool for putting these in, I'll go ahead and attach the trees, forks and wheels.
Now for the questions:
WHO was the masochist who designed the #2 and #3 cylinders on the 500 to be so small that a deep well socket won't fit inside the hole?  So therefore, HOW do you get the spark plugs in & out of those cylinders?
Regarding plugs, the ones that came out of this 500 were NGK D7ES plugs.  Are these what you guys run in the 500s and 550s?
« Last Edit: August 23, 2015, 02:28:53 PM by Restoration Fan »
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #168 on: August 23, 2015, 03:35:32 PM »
Ron,
When I was actively working on Fiberglass Boats and getting parts of them ready for paint, my Mentor told me to grab any old Spray bomb type black paint.  He generally used Rustoleum cause it was super cheap.  LOL
His explanation for the "guide coat" was, all you are looking for is high spots and low spots.  You don't spray on a coat like you are trying to cover everything, you just want enough so you can see where the highs and lows are.  It's all going to get sanded off anyhow.
His approach worked like  a charm for me, anyhow.  Just some insight and not meant to get people running for their Popcorn.  LOL
And PS, the engine and frame are looking really good!!!!!
Oh, and I have no idea why Honda did that with the #2 & #3 spark plugs on the 550!!!  But there is a flexible shaft, maybe wire, kid of like one of our control cables only thicker.  Maybe you can use something like that to put those plugs in with a thin wall socket????
Something like this http://www.ebay.com/itm/like/261661433758?ul_noapp=true&chn=ps&lpid=82
Charlie
« Reply #169 on: August 23, 2015, 05:06:35 PM »
Thanks for the input, Charlie.  I'm hoping one of the 500/550 guys will chime in with what they use to get to those 2 plugs.  I actually have to get the old 2 out of the engine before I can put new ones in.  When I pulled the plugs from #1 and #4, they were in pretty bad shape so I definitely need to replace them.
By the way, I've been enjoying following your thread.  Looks like you're getting close to having her going if the weather will ever cool down.  (One reason I'm REALLY glad that I have my workshop in my basement; it allows me to work on the bikes even when the weather is 100 outside.)  The problem I've been having with these bikes is that I haven't had as much time to work on them because I've been out enjoying riding on Stella so often.
« Reply #170 on: August 23, 2015, 05:24:45 PM »
Hey Ron....It must have been a very small Japanese engineer that designed the 500 motor!
I would only attempt removal with the OEM Honda spark plug wrench, it works perfect.  To install. a 10" piece of flexible tubing attached to the plug works pretty good to get it started.
Here the plug wrench, you may find one cheaper from someone here but this will give you an idea of what you need.
 http://www.ebay.com/itm/HONDA-CB350F-CB400F-CB500-CB550-CB750-GL1000-SPARK-PLUG-WRENCH-OEM-NEW-18-/231653919755?hash=item35efa64c0b&vxp=mtr
« Reply #171 on: August 23, 2015, 05:33:42 PM »
Stev-o,
AWESOME.  Thank you for the link.  I hit the button and hit the Buy it Now to purchase it but right before I clicked on the button to pay for it, I realized that I have one of those that came in the box of parts I bought.
So I went in and found the tool but it does beg another question:  the tool goes down into the hole and onto the plug but it just barely comes out of the hole.  There are 2 holes in the wall of the tool that makes me think there is supposed to be some type of handle that fits with this tool.
I'm sure I can make it work but it's low enough that it will be difficult to stick a screwdriver through the hole without marring the paint job on the engine.  Am I missing something?
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #172 on: August 23, 2015, 07:36:29 PM »
Awesome great progress!
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #173 on: August 23, 2015, 10:39:25 PM »
Looking forward to seeing you get Logan's runner on the road.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #174 on: August 24, 2015, 04:33:51 AM »
Yes, the two holes are for a "handle" that is simply a straight round rod. A screwdriver will work the same, so if your socket tool is too short then you might try to find a longer one. I have seen them in at least two, maybe three, different lengths.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
