Author Topic: gas leaking everywhere!  (Read 1538 times)
Offline 75 super sport
« on: May 13, 2015, 09:42:03 PM »
Fired the bike up for the first time, gas leaking from everywhere. Coming out of the fitting that shares fuel with 1&2 and 3&4. Pouring out of #3 as well. Had them rebuilt last year but that sat around until now. Not sure what to do. Rebuild them again? Any suggestions on what may be going on?
"Smoke em if ya got em"
Offline Davez134
Re: gas leaking everywhere!
« Reply #1 on: May 13, 2015, 10:04:54 PM »
The fittings have O-rings, replace. Float may be stuck on #3 or float needle/seat may be worn or have debris in there. Try this first before just rebuilding everything.
« Reply #2 on: May 13, 2015, 10:12:01 PM »
Do the o rings for the fittings come in a rebuild kit? The kits are fairly cheap
Offline Davez134
« Reply #3 on: May 13, 2015, 10:38:03 PM »
Without looking at the specific kit, I couldn't tell ya, but usually no. There are 4 rings on each fitting, you will need 8 total, and I believe they are 2mm thick x8mm diameter. Waaaay cheaper than a complete rebuild kit.
« Reply #4 on: May 14, 2015, 04:27:49 AM »
Do you know where I can find them?
Offline Davez134
« Reply #5 on: May 14, 2015, 04:51:37 AM »
Harbor freight oring kits, any hardware store that sells orings. Not hard to find.
« Reply #6 on: May 14, 2015, 04:57:00 AM »
I took mine to Lowe's and found the right size of o-rings.
The HF o-ring kit is a great thing to have too.
Offline Johnie
« Reply #7 on: May 14, 2015, 05:24:09 AM »
NAPA o-ring part number 727-2605. The only way to replace those is to separate the carbs which why some people take short cuts and don't change them out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #8 on: May 14, 2015, 06:55:31 AM »
As these orings only contact fuel, and are not exposed to excessive heat, at a minimum, use BUNA-N, orings.
VITON(FKM) are also fuel resistant, but have a higher heat rating.
« Reply #9 on: May 14, 2015, 07:10:22 AM »
So the ones from Napa, are they ok to use?
« Reply #10 on: May 14, 2015, 08:01:26 AM »
i dont work at napa, so i dont know.  guess youre going to have to ask  :P
use buna-n  or viton, only....
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: May 14, 2015, 08:57:17 AM »
Am I the only one that doesn't know what bike he has? 75 all three sizes came in Supersport models. I would just buy the Honda gasket carb kits for $15 each. Then you know you will have all gaskets and o-rings made of quality material in the perfect sizes. They are readily available for the 550F carbs, probably for the 750F, not sure about the 400F.
Most guys will tell you not to sepearate the carbs but it's not rocket science and I always feel better knowing the fuel 'T' orings have been changed. Plus its easier to change out the fuel lines when the carbs are seperate and the fuel T removed.
« Last Edit: May 14, 2015, 08:58:58 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #12 on: May 14, 2015, 09:54:08 AM »
75 cb750f. I bought 4 carb rebuild kits and a bunch of Vinton 8mm x 2mm gaskets for the "t"s. Should work eh?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: May 14, 2015, 10:00:46 AM »
The kits didn't come with the T orings? Strange.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #14 on: May 14, 2015, 10:14:23 AM »
No I don't believe so
Offline Johnie
« Reply #15 on: May 14, 2015, 11:18:46 AM »
I have only used the NAPA o-rings. My KO has had them in now for 9 years. They will be fine.
Oshkosh, WI  USA
Offline Bodi
« Reply #16 on: May 15, 2015, 08:15:19 AM »
The Honda OEM carb gasket kits come with the crossover o-rings. Not as cheap as aftermarket kits, or just getting o-rings locally. You do get the cap gasket and a bowl gasket o-ring as well. These OEM parts are not 100% ethanol resistant as of the last kits I bought, mid 2013.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #17 on: May 15, 2015, 09:25:19 AM »
Go with Viton if you can.
« Reply #18 on: May 15, 2015, 12:19:56 PM »
I got some Viton o rings on the way :) so what would make the carb fill up and over flow out of the intake side of the carb and flood into the motor? Brand new top end with 836 big bore and I really do not want to harm the motor!
« Reply #19 on: May 15, 2015, 12:42:33 PM »
Leaky float valves. I just shut off my petcock when I park it for more than 5 minutes.
