Author Topic: Show me your swaps!!! Engines, front ends etc.  (Read 2992 times)
Offline hellraiserDLX
« on: May 14, 2015, 09:21:06 AM »
 This is my 1977 cb550f supersport. I swapped in a 1982 cb650 engine and a 2002 GSXR1000 front end. Harley complete wheel up front and a 18x3.5" harley rim laced to the stock 550 hub in the rear. Going to button up a few more little things this evening and take it out for a long ride to see what kind of problems i may have. Wish me luck!
« Last Edit: May 14, 2015, 10:09:10 AM by hellraiserDLX »
Re: Show me your swaps!!! Engines, fromt ends etc.
« Reply #2 on: May 14, 2015, 09:55:54 AM »
Those the stock 650 carbs?
1978 Honda CB550K
Those sure do look like stock CV carbs for a 1981-1982 CB650!
« Reply #3 on: May 14, 2015, 09:57:32 AM »
1977 CB750K7 frame and engine with 1976 GL Front End (forks, brakes) and 1976 gas tank
Offline DaveBarbier
« Reply #4 on: May 14, 2015, 09:58:54 AM »
1978 Honda CB550K
I'm far from having that kind of knowledge of SOHC4s, haha. Thanks
1978 Honda CB550K
« Reply #5 on: May 14, 2015, 09:59:42 AM »
1978 Honda CB550K
yes sir!
« Reply #6 on: May 14, 2015, 10:03:23 AM »
that's beautiful!
« Reply #7 on: May 14, 2015, 10:07:46 AM »
My K8 with an F3 engine
Re: Show me your swaps!!! Engines, front ends etc.
« Reply #8 on: May 14, 2015, 10:12:14 AM »
I see your K8 and raise you K3 - with F3 engine  ;D
« Reply #9 on: May 14, 2015, 10:25:50 AM »
showoff   ::) :P
triple discs too, nice  8)
« Reply #10 on: May 14, 2015, 11:02:48 AM »
Prokop,
How about some closer up shots of that K3F?
« Reply #11 on: May 14, 2015, 11:03:22 AM »
that's beautiful!
Thank you!!
« Reply #12 on: May 14, 2015, 11:29:19 AM »
Prokop,
I am working on it, but she looks better from a distance  ;D
« Reply #13 on: May 14, 2015, 12:16:12 PM »
Prokop,
NO, she is not good from far but far from good.  I don't believe it for a second.
Offline wowbagger
  • Not much of an
« Reply #14 on: May 14, 2015, 04:33:25 PM »
Here's my "CB525."  ;D
It's a 1973 CB500 frame with a 1972 CB500 engine and all the horrid bits from the 1978 CB550. Oh, and 12 over forks just to cinch the ugly award. I rescued this from a field. I'll be reverting it to a stock CB500.
« Reply #15 on: May 14, 2015, 05:00:53 PM »
That's a beauty!  I wonder if the PO had to order EXTRA LONG FORK GAITERS to span the 12 overs.  What do you mean by "all the horrid bits from the 1978 CB550"?
Offline wowbagger
  • Not much of an
« Reply #16 on: May 14, 2015, 05:04:21 PM »
Yeah, I have no idea where the PO found those gaiters but they are the size of two standard gaiters joined together.
By "horrid bits" I was mainly referring to the seat, bars and sissy bar. Though, I was never a fan of the later cb500/550 tail light either.
Markcb750
« Reply #17 on: May 14, 2015, 05:08:15 PM »
This is my 1967 black bomber with CBR250 front & rear suspension.  Also using the 250R foot rests & foot controls.
At the welder now to be professionally finished after I aligned and tack welded in place as you see in the pic.
« Reply #18 on: May 14, 2015, 05:29:24 PM »
The 77-78 pipes are not as nice either.
Offline wowbagger
  • Not much of an
« Reply #19 on: May 14, 2015, 05:46:37 PM »
I agree they are not as nice but at least they are more readily/reasonably available.
