Author Topic: 1970 CB750 carb questions  (Read 1334 times)
Offline DaveInTexas
  • 1970 CB750
« on: May 15, 2015, 02:16:19 PM »
A)  In my CB750 Shop Manual, there are notes on how the needle height can be adjusted - but I do not see anything on the technique to decide when or how much it needs adjusting.
Is this mainly a low speed f/a adjustment?
B) Is it correct that the only high speed f/a mixture adjustment is the jet size?
Offline Davez134
Re: 1970 CB750 carb questions
« Reply #1 on: May 15, 2015, 02:39:20 PM »
The first 2 posts in this link should answer both questions in depth for ya. It's from carb FAQ section. I have referred to this many times...
http://forums.sohc4.net/index.php/topic,5410.0.html
Offline DaveInTexas
  • 1970 CB750
« Reply #2 on: May 15, 2015, 03:44:11 PM »
Thank you for pointing this out, I will review and return if I have unanswered Q's.
Offline DaveInTexas
  • 1970 CB750
« Reply #3 on: May 15, 2015, 03:49:22 PM »
OMG isn't that the motherlode of all things carburetor.
Offline Davez134
« Reply #4 on: May 15, 2015, 06:59:32 PM »
I know right! Figured it would be easier to send ya there than try to explain throttle positions. Don't know what I would have done without that info!
Offline DaveInTexas
  • 1970 CB750
« Reply #5 on: May 15, 2015, 10:46:45 PM »
Ok I ploughed through all that plus my manual plus Clymers and have decided that (post corrections, please) :
It looks like it is adjusted if the mixture at 1/2 to 3/4 throttle position is too lean or rich only.
This is correct as far as I could find in my readings; anyone?
« Last Edit: May 16, 2015, 10:53:46 PM by DaveInTexas »
