Author Topic: Main fuse blows when I turn the headlights on  (Read 1227 times)
Offline yanks8
« on: May 16, 2015, 06:49:26 AM »
Hello all, I'm new to the forum and currently restoring a '75 CB750k and I'm having a problem with the main fuse blowing when I turn on the headlights. I didnt have that problem until I went to a differant type handle bar and pulled the wires out of the original bars. I feel that I have all wires hooked up correctly and have continuity on on all wires except a black wire coming from the right side. Any thoughts or advice would be really helpful and appreciated.  Thanks Tom
Offline riverfever
Re: Main fuse blows when I turn the headlights on
« Reply #1 on: May 16, 2015, 07:55:16 AM »
Sounds like you have a short somewhere. When I switched to clip on bars I had the same thing happen. Bike would die (because of a blown main fuse) when turning the bar to the right. Finally found a tiny spot in a wire that had been pinched and every time I turned far enough to the right a bit of bare wire would hit the frame and pop that fuse. Look very carefully.
Offline yanks8
« Reply #2 on: May 16, 2015, 10:23:48 AM »
Thanks Riverfever I'll check that out
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: May 16, 2015, 02:13:04 PM »
Also check your bar switches. I nipped a wire installing mine.
