Author Topic: 1973 cb750 Project "Blackout" slow but steady  (Read 1553 times)
Offline TheCampingPost
« on: May 18, 2015, 11:42:54 AM »
I'm 17 got this cb750 in a trade trying out a cafe style build, and the guy did a lot of motor work apparently including an engine swap so really don't know how many miles there are on the motor but it's pretty clean when I took the valve cover off. He extended the swingarm and lowered the bike by taking the springs in the back out and just puting a spacer, but everything is being taken off and being fixed or replaced. Looking for advice on what to look for or what to replace to make this more reliable and economic. What are any to all problems with this bike that can be fixed. Some background: I've been working on and fixing things with motors since I was 10 or 11 built a model car when I was 4 and since then I've loved building things I live in monrovia California about 30 minutes east of Los Angeles. This is going to be a pretty low budget build. Thanks for reading and thanks for replying. I have an Instagram setup just for this build that will have lots of photo updates probably day by day https://instagram.com/projectblackoutcb750/
I'm 17 and I have absolutely no clue what I'm doing.
"Do What You Can, With What You Have, Where You Are" – Teddy Roosevelt.
Current Projects
1973 cb750
1984 cb700sc
My Instagram is just small current updates made day by day
Re: 1973 cb750 Project "Blackout" slow but steady
« Reply #1 on: May 18, 2015, 12:39:50 PM »
Is the motor seized or free.  If free, you should try giving it a major service and seeing if it will run.  This will most assuredly require rebuilding the carburetors if they have been sitting for an appreciable amount of time.  The motor does not look too crusty and has some aftermarket pieces.  I would then go through it system by system (forks, brakes, shocks, electrical).  See if you can get it into a running bike before you start converting it to a café.  The time spent getting it into running shape will give you a chance to get to know what you like or don't like about the bike to modify later.
« Reply #2 on: May 18, 2015, 02:48:58 PM »
The motor is not seized (anymore) very light rust in one cylinder. I already took apart all of the carbs need a few small parts in them. Here's what I've done so far. I know it's a mess but I learn where everything goes
Current Projects
1973 cb750
1984 cb700sc
« Reply #3 on: May 18, 2015, 04:28:09 PM »
Well, so much for taking the teardown in steps!  ;)
What do you plan on tackling first?
« Reply #4 on: May 18, 2015, 08:17:51 PM »
Cleaning and painting since my dad can get parts powder coated very cheap at work. But before while iver urging is dirty I'll try starting it
Current Projects
1973 cb750
1984 cb700sc
« Reply #5 on: May 18, 2015, 09:43:59 PM »
That's definitely an incentive!
