Author Topic: Installing 836 pistons  (Read 2146 times)
Offline martin_uk
  • CB750F1 CB750K8
« on: May 21, 2015, 08:32:14 AM »
I am at the point of fitting the cylinders (jugs) to my no3 CB750.
I have the 65mm pistons from Cruisin Image and am finding the pistons/rings are difficult to insert.
I believe part of the problem is with the overbore as I have lost the lead in at bottom of bore.
My 60-65mm clamps were too small and 65-70mm a bit too big as slip off rings before inserted.
Doing on my own and may be better with 2 to control clamps.
May try a cut down beer can to reduce larger clamp.
Interested to know if others have found same issue and found a solution?
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline teebee67
Re: Installing 836 pistons
« Reply #1 on: May 21, 2015, 08:52:45 AM »
Had the same problem - ended up cutting a very slight chamfer to the bottom of the liners with a rotary burr (could easily do it with a file). Only a very slight chamfer and, hey presto, they went in easily (this was after several hours trying to fit them myself and an hour or so trying to fit them with a mechanic friend.
I'm only old on the outside.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #2 on: May 21, 2015, 09:20:26 AM »
Thanks its good to know I am not alone  :D
Offline voxonda
« Reply #3 on: May 21, 2015, 09:55:46 AM »
Do you use two U-shaped piston supports Martin? I do it alone all the time. Just take your time.
« Reply #4 on: May 21, 2015, 12:17:56 PM »
So my liners are improved by my tuner that bored my cyl block to 65mm? No problem to get the pistons in with rings, no tools except fingers.
I did things in wrong order, honed bores then cleaned the head. Corroded bores within a few minutes :(  Dried them and oil did not remove the stains.
« Last Edit: May 21, 2015, 12:22:39 PM by PeWe »
Offline Big Jay
    • CBRzone
« Reply #5 on: May 21, 2015, 05:20:20 PM »
Not a problem when the shop is ised to doing big bores and they put the chamfer back in the bottom of the sleeve.
« Reply #6 on: May 21, 2015, 07:05:28 PM »
Without the taper at the bottom, it will be VERY difficult to install the oil rings without breaking them. The machine shop should have known that? I have mine always apply the taper again.
« Reply #7 on: May 21, 2015, 07:49:59 PM »
Easy $hit.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #8 on: May 22, 2015, 03:52:21 AM »
I used a chamfer tool to create lead in, plus used longer screws from bigger clamps with smaller clamps to get a good fit.
Was able to fit OK and I thought great, then noticed I had forgotten to fit the 2 knock pins (dowels) Dohhhhhh :-[
It would be easy to fix without removing cylinders if the studs were not so tight, so looks like I will have to start over.
« Reply #9 on: May 22, 2015, 06:20:23 PM »
Ow!
I wish I could say that I haven't done that myself, but you'll notice the silence on the next line:
At least you're practiced at it now?
« Reply #10 on: May 23, 2015, 12:27:19 AM »
If the studs are the old OEM they can be tight.
I could remove all of my old studs with double nuts only. I found it was easier to do a quick short jerk, tighten even more then loosen them. I removed all my later HD studs whithout lifting the cylinder block, head only. I tried with head on but the 4 shorter studs were too trĂ­cky.
They had not be sitting for long and had to be replaced due to excessive torque over the spec. and I was worried that they should snap when driving.
« Last Edit: May 23, 2015, 01:04:49 AM by PeWe »
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #11 on: May 23, 2015, 07:04:50 AM »
I used my hone. Nice and uniform all the way around. I just moved it ever so slightly on that top ridge to round it a bit and they slid in like butta.
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline martin_uk
  • CB750F1 CB750K8
« Reply #12 on: May 23, 2015, 10:10:32 AM »
Second time was easier, but still a fiddle.
2015_0522after0005 by nitram2010, on Flickr
2015_0522after0011 by nitram2010, on Flickr
