Author Topic: '78 750K first project by a car guy...  (Read 35098 times)
Offline RandyBMC
Re: '78 750K first project by a car guy...
« Reply #50 on: October 02, 2015, 08:10:55 PM »
Ugh, trying to upload straight from the iPhone doesn't seem to work - it says it can't accept .jpeg, only .jpg...
Back to finding time to upload to photobucket and use the img tags.
The rings - there is definitely not a pip or mark on the top of any of the rings.  I am 90% sure the silver edged top ring can go up or down, since the chamfer is on both edges.  I am less sure on the 2nd ring.  It seems, even with a magnifier, that the edges are straight (square).  I've always seen either a slant or a lip/step on the 2nd ring to "scrape" the cylinder wall (for break-in mostly, but I'm not sure that it doesn't help compression).
Has anyone seen a 2nd ring like that, and maybe the Japan eBay 836 kit has those (the kind with no slant or lip)?  My next step is to eBay communicate with cruisin' image (the eBay vendor).
Thanks again for everyone's input.
« Last Edit: October 02, 2015, 08:12:43 PM by RandyBMC »
Offline RandyBMC
« Reply #51 on: October 02, 2015, 09:13:17 PM »
The new workplace
The eBay CruzinImage 836 piston kit, which I'm pretty happy with
Painting the cylinders
Painting the block
Looking at it all coming together
The stripped tank looking industrial (still plan to paint)
« Last Edit: October 11, 2015, 08:06:20 AM by RandyBMC »
Offline Desert-SOHC
  • It's old
« Reply #52 on: October 02, 2015, 09:29:34 PM »
Coming along nicely
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #53 on: October 02, 2015, 11:32:33 PM »
Nice job on the engine paint.
Offline hondamad
« Reply #54 on: October 02, 2015, 11:40:39 PM »
Looking good , i suppose you are itching to ride it
Offline Restoration Fan
  • My wife will never call me
« Reply #55 on: October 03, 2015, 03:13:19 AM »
Nice work, Randy.
A couple of things:
1)  The rings we received for our 78 didn't have numbers on one set of those.  If you find that there are no numbers but one side is a bit shinier than the other, put the shinier side facing the top.
2)  There's an iPhone app for PhotoBucket that is free.  Download that and then hit the "Upload" button on the lower left of the screen.  You can then select the photos straight from your photo roll on your phone and upload them.  It works; I do it all the time.
Good luck man.  I still have a few 78 parts still laying around.  If you find you are in need of something, give me a shout and it's yours if I have it.
Offline RandyBMC
« Reply #56 on: October 06, 2015, 07:23:43 PM »
Well, the piston install was fun.
Clocked the rings, installed the rings as I thought they should be - with the dual beveled silver lipped ring on top, the square edged number 2, and the oil rings.  No top or bottom orientation.
Installed onto the rods, slapped on some good old Permatex aviation 3 to the cylinder gasket and block, then used a combination of Popsicle sticks and generic ring compressors from Pit Posse (the Honda ones would've worked better as they are smaller).  A piston base stay would've helped too, but I made it work.
Now I am working toward getting the head on - installed the pins and rubbers, but the knock pins that locate the gasket on the cylinder and the head to the cylinder seem to be keeping the head gasket from laying flat.  I tried two different gaskets, same deal.  I swapped the pins and tried upside down and right side up on them as well, no joy.  I posted the photos at the end of the progress work.  Really hoping for some input!
A shot of the drag bars I'm going to use.
The issue with the head gasket.  The knock pin is not completely down in the photos, but they have been every which way and I can't make either gasket lay flat.  The holes all line up almost dead on otherwise.
Offline FGKouki
« Reply #57 on: October 07, 2015, 08:53:27 AM »
You can enlarge the holes on the headgasket with a dremel  and it'll fit great.  I've had to do this with both the engines I rebuilt and I think it's common with most aftermarket gaskets.
Offline RandyBMC
« Reply #58 on: October 07, 2015, 10:05:25 AM »
Great, thanks for the tip.  I already went out to the garage this morning and did just that.  It fits like a glove now.
Advice on dry or not for the head gasket?  On the old stuff I worked on in the past, I used Permatex on all gaskets except for the head gasket (which would go on dry).
Offline RandyBMC
« Reply #59 on: October 08, 2015, 06:21:04 PM »
Without further input from anyone that knows better, I have decided to put the head on with the gasket dry.  I put it on to check clearances, and all looks good - except that the head needs to go black now that I see it all together...
Then I used a shop light since I don't have an oven, and the valve stem seals are already installed, to do a semi-baking job.
I think it'll be worth the extra time in the end (taping off is a royal pain!).
I then found that I am missing a couple o-rings (the 11x2.5 pair that go with the head gasket and base gasket on each top and bottom of the cylinder).  I called and spoke with Mike at CycleX and he was super great and sent me a couple at no charge (I bought all of my cylinder head stuff from them)!  They are on the way.
My daughter then helped with some thoughts on the paint for the tank.  I would like to give a retro feel and nod to Honda with maybe a Super Sport style stripe on each side.  It's still in the works.  The grey is a non-metallic, dove grey like Toyota uses on the FJ or Audi/VW uses.  I think MINI has one too.  I'm leaning toward the grey tank with the black stripe and blue outline - opinions welcomed.
While waiting for the o-rings to show up, I will probably start on the frame and forks.  Is it the inner shoulder that folks recommend massaging with a grinder to assist in installing/pulling the engine?  On the right side forward lower mount?
Thanks again for the help and any opinions.
« Last Edit: October 08, 2015, 06:23:45 PM by RandyBMC »
« Reply #60 on: October 08, 2015, 06:33:40 PM »
  I don't know how to use photoshop either.... :P ;)
I like the F2 style paint ideas... ;)
Offline RandyBMC
« Reply #61 on: October 11, 2015, 08:09:49 AM »
Found the issue on this page that was making the font small - whew!  It was too hard to read.
For those that missed the questions because of the tiny font, there were two:
1.  Does anyone use anything on the head gasket, or do you put it on dry (my inclination, and what I read in the manual state dry, but I don't want to negate those with years of knowledge on this bike)?
2.  Now that I am starting on the frame, should I grind the lower front, right engine mount flange down level to the top of the mount for easier installation and do you have photos?
Thanks!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #62 on: October 11, 2015, 08:13:23 AM »
1. I have had good results mounting the head gasket dry
2. Yes. Just grind the bumps on top down flush.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #63 on: October 11, 2015, 08:22:39 AM »
1. +1 Dry, however, I had a small leak on my Kaw, I replaced the gasket and reinstalled with a light coat of Permatex Copper spray a gasket, no issue since.
What gasket set are you using?
Have you heard of Hondamans book?
Offline RandyBMC
« Reply #64 on: October 11, 2015, 08:36:49 AM »
The one that came with the CruzinImage pistons.
I have heard great things about Mark's book, but every time I get $85+ there is stuff I need for the motorcycle (like his ignition set up!).  I'm sure it is more than worth the cash, I just have to sparingly use money for the bike project or sleep on the couch.
« Reply #65 on: October 11, 2015, 11:32:56 AM »
Same here.  We didn't put any gasket sealant on the head gasket.  Used the Vesrah head gasket that came in the Vesrah kit.  Tightened it down, let it sit overnight and then re-torqued it again.  Successful so far.
« Reply #66 on: October 11, 2015, 11:36:20 AM »
Randy,
You have downloaded the version of the Honda manual that is specific to the K8/F3 models, haven't you?
If not, you can download it from my Google Drive location.
https://drive.google.com/open?id=0B4nqeBb662mZTExFNDdwY0JyRlU
Offline RandyBMC
« Reply #67 on: October 11, 2015, 12:54:05 PM »
I do have that one.  I have been using the other shop manual (blue and white cover with the wheel) because I printed that one out before I found the '78 manual.  I refer to it though using the iPad.
Thanks for the link!
« Reply #68 on: October 11, 2015, 04:34:38 PM »
A word of caution; a fair amount of things changed in the 77 and 78's.  You'll find quite a few variances (carbs, breather beneath the battery box and the hose routing there, rear wheel size, rear wheel hub, choke cable vs on-carb choke) on your bike from that manual.  Just make sure you check the 78 manual if something doesn't look right.
Offline RandyBMC
« Reply #69 on: October 11, 2015, 05:28:43 PM »
Thanks Restoration Fan.  I have been doing just that with the iPad manual from your Google Drive - it has been very helpful.  Since my bike came in baskets, I've had to figure out just what it's supposed to look like.  At least the engine was still on the chassis.
Speaking of figuring out what it's supposed to look like, I took off the center stand and removed the forks today.  Found an interesting spring set up between the center stand and the rear brake actuator.  I took a few photos of it if I ever want to reinstall the center stand (I plan to just find a side stand for it).  Thought it may be helpful to anyone else needing a reference:
I also worked pretty hard tonight to revive the forks.  Before and after (actually side by side, but you get the picture).  Someone already had a half hearted go at cleaning them up with what looks like a grinder!  I was able to clean the marks up by polishing it out.
Now I need to rebuild them with a progressive kit.  I am thinking of doing a shorter spring in the front - input?
« Reply #70 on: October 11, 2015, 05:37:07 PM »
Nice polishing!  Why shorter spring?
I installed Progressive springs in my K4, it comes with a spacer you can install to adjust preload.
Offline RandyBMC
« Reply #71 on: October 11, 2015, 07:38:16 PM »
Being new to bikes, I have to admit some ignorance.  I thought to lower the bike's front, you would need a shorter spring (similar to how you lower a car).  I didn't want to lower the bike by just moving the forks up in the triple, as I thought you would lose travel that way.
So I guess a question is in order - what's the proper way to lower the front of the bike?  And is that advisable for handling (I was under the impression that lowering the front and having rake improves turn-in)?
« Last Edit: November 06, 2015, 03:30:35 PM by RandyBMC »
« Reply #72 on: October 11, 2015, 07:51:49 PM »
You could shorten the tubes to lower the front end but I wouldnt do that.
I suggest getting the bike put together, running and riding safely, then upgrade the suspension as you see fit.
Unless you are an advaced rider and plan to carve canyons or track it, I think you'll find the CB a fairly good handling vintage bike.
However, replacing 35+ year old springs and shocks is a good idea.
Offline RandyBMC
« Reply #73 on: October 11, 2015, 08:28:17 PM »
Exactly - so I figured while I was going to replace them, I would make it handle as best as possible with the stuff I'm buying.
Great advice though!  I agree and that's my plan.  Make it all work, then tweak.  But if I am changing it out anyway, what should I use...
« Last Edit: November 05, 2015, 07:55:22 AM by RandyBMC »
Offline RandyBMC
« Reply #74 on: November 05, 2015, 11:12:20 AM »
I've been doing lots of odds and ends waiting for o-rings.
I wire wheeled the whole frame in prep for the chassis paint.
I also went shopping!  Lots of goodies have been arriving.  I got new All Ballz bearings for the wheels and the neck, as well as fork seals.  My ignition was a butcher job, and it didn't have a key, so I bought one of those.  Speaking of butcher jobs, I went ahead and bought a new wiring harness, as the old one had a combo of splices, solder, duct tape (no kidding), and crimps that made me cringe a bit.  I got new coil packs and condensers too.  I bought new swing arm bushings, rear shocks and Progressive front springs as well (those haven't arrived yet).  I also bought a polished engine bolt kit from Alloy Bolts.  My brake handle was broken, so I got one of those along with the front brake wiring switch.  I also needed front fork seal retainers and the seal to rebuild the caliper.  The stuff really adds up!
I received the seat - decided to go with a Tuffside and I am really happy with the decision.  I hooped the back and it turned out well I think.
I also inserted the brass bushings into the swing arm.
I rebuilt the front caliper and installed a new bleeder.  I also polished it (along with a few other items).
I am now waiting for water to boil to try to get the pesky fork seal removed.  Work continues...
