Author Topic: 1973 CB350F Build Log -- First Bike -- FINALLY FINISHED!!!  (Read 17667 times)
Re: 1973 CB350F Build Log -- First Bike -- Army Green Cafe Style
« Reply #50 on: June 10, 2015, 10:05:42 AM »
The matte paint on the frame is nice.  That shock is shot.  I would just buy a set of Hagons for it.
Offline GizmoDuck
« Last Edit: July 04, 2015, 08:38:29 PM by GizmoDuck »
« Reply #52 on: June 10, 2015, 12:14:24 PM »
Would these work? They are an inch shorter than stock.
For unknown reasons, you picture is not coming through on my browser.  The image link is for an Emgo shorty shock.  The Emgo stuff is cheap but I would not use their shocks.  If you have stringent budget issues, look at the Hagons or even the Progressive shocks.  A shorty shock will also disturb the handling of the bike.
Offline GizmoDuck
« Reply #53 on: June 10, 2015, 01:16:59 PM »
Thanks!  Where would you recommend buying Hagons from?
« Reply #54 on: June 10, 2015, 02:46:02 PM »
You can buy them direct from Hagon.  They are located in San Diego, CA.  760-798-8015
http://hagonshocksusa.com/
Offline GizmoDuck
« Reply #55 on: June 13, 2015, 01:54:44 PM »
Got almost all of my new parts, still need brake lines and throttle cables, and going to start putting it back together. Planning to lay my engine sideways and slide the frame over it bot it on, put forks on, pop the center standout the swing arm and wheel on. Then everything else. Anyone got a better way of putting a motor in a newly painted frame that will reduce the risk of scratches and be kind to my back.
Offline calj737
  • I refuse...
« Reply #56 on: June 13, 2015, 02:38:18 PM »
Hire 3 burly men? I think your method works like a charm, actually. Apply some blue painters tape to the frame while you wriggle the motor in to protect the paint.
Offline GizmoDuck
« Reply #57 on: June 16, 2015, 12:14:10 PM »
Painted almost everything that needed it
Motor back in the frame
Now to buy a few more pieces and put it all back together.
Offline calj737
  • I refuse...
« Reply #58 on: June 16, 2015, 12:17:55 PM »
before you strap all that back together, make sure you have bare metal or the battery ground to the frame, and between the motor and the frame. It does make a difference in your electrical system and charging.
Offline GizmoDuck
« Reply #59 on: June 16, 2015, 12:34:29 PM »
At every bolt or just a few?
Offline calj737
  • I refuse...
« Reply #60 on: June 16, 2015, 03:54:49 PM »
Just for the NEG strap. On the 550/750 the NEG gets pinched between the mount, frame and motor. Not 100% on yours, but if so, clean to bare metal that lug on the motor, and the mount.
Offline GizmoDuck
« Reply #61 on: June 17, 2015, 06:49:06 AM »
Yeah it is the same setup. Thanks for the reminder I would have missed that.
Offline GizmoDuck
« Reply #62 on: June 19, 2015, 04:52:11 PM »
Gas tank stripped and coated in rust neutralizer
All cleaned up
Caswell liner curing
New All Balls roller bearing races installed
Installing bearings
Put old bearing race on the new bearings, placed a 1 1/4" galvanized pipe on top of that and hammered away on a piece of oak to press new bearings into place
Removed logos to sand and paint side covers.  Found CB350F shocks on eBay for $20, cut down spring guard, and painted the springs.  Should have plastic dipped them but I didn't want to drive to the hardware store.
Offline GizmoDuck
« Reply #63 on: June 30, 2015, 09:47:09 AM »
Pic updates
Cleaning rust off wheels
Cleaned out
Primed and painted
Tires
Sanding everything down for paint
New drum brakes
Replacing sprocket
Were these supposed to come out with sprocket?
Next up: wheel bearings, front brakes, swingarm, shocks, then putting wheels back on.
Offline calj737
  • I refuse...
« Reply #64 on: June 30, 2015, 09:52:20 AM »
Spokes look a little battered up from rust. No plan to replace them?
Also, be sure to leave a bare metal "ring" around the top of the filler cap. That prevents the fuel from seeping under the paint and lifting it off as it comes down the filler neck. I generally tape off about 1/4" from the top, then sand it to fully bare. Spray from there down to the tank body.
« Reply #65 on: June 30, 2015, 10:27:19 AM »
If you are not going to replace the spokes, you may want to remove the oxidation with scotchbrite pads and steel wool, and then clear coat them for protection.  This assumes that the oxidation is only superficial.
Offline GizmoDuck
« Reply #66 on: July 02, 2015, 10:26:57 AM »
Thanks guys!  I am planning on keeping the spokes for now.  Will scrub them down and clear them!
Offline GizmoDuck
« Reply #67 on: July 04, 2015, 08:37:04 PM »
Replaced the wheel bearings and almost finished up with the wheels
Removed the bearings out using a concrete anchor
Front wheel bearings removed wedging two screwdrivers and the bolt from the anchor I used to do the rear wheel
Improvised tool for retainer ring
This works too but resulted in some blood blisters when it slipped
Front done
Rear bearings out
Done
Now to rebuild the front brake, fork seals, shocks, swing arm, and put the wheels back on
Offline GizmoDuck
« Reply #68 on: July 09, 2015, 01:46:53 PM »
Rear wheel done
Offline GizmoDuck
« Reply #69 on: July 14, 2015, 10:05:36 AM »
Finally Got the forks apart.  After several recommendations I went and got a $20 torch and had those stuck bolts out in no time.  Had to get them fairly hot but it worked!
One more coat of primer needed before final wet sand and topcoat
Offline calj737
  • I refuse...
« Reply #70 on: July 14, 2015, 10:41:17 AM »
Make sure to re-anneal the washer before reinstalling that bottom bolt. It is required to prevent leakage
« Reply #71 on: July 14, 2015, 11:07:35 AM »
How did that old fork oil smell?  Probably the nastiest smell ever out of my motorcycle.
Offline GizmoDuck
« Reply #72 on: July 15, 2015, 09:43:33 AM »
So heat it up and cool it down in water?
HA! With my allergies I couldn't smell a thing but my kids both said "that smells like poop" dropped their screwdrivers and ran inside LOL
« Reply #73 on: July 15, 2015, 11:49:23 AM »
That's about right.  It's weird how oil can take on that smell.
Offline GizmoDuck
« Reply #74 on: July 20, 2015, 03:20:47 PM »
Painted side covers and tank. First, is a good shot of the tanks lines and second is a shot that shows off the metal flake.
