Author Topic: CB750 Oil Pump shaft runout. Really?  (Read 918 times)
« on: May 23, 2015, 04:05:37 PM »
On my CB750 oil pump, I reassembeld it and in passing noticed that by pulling on the gear, I can pull the shaft in and out about 1/4 - 3.8 of an inch is that right?
Pushed in:
Pulled out:
I disassembled it, everything in place, mostly just 2 pins and the 4 rotors.
Offline brandEn
Re: CB750 Oil Pump shaft runout. Really?
« Reply #1 on: May 23, 2015, 05:02:06 PM »
I have a couple known good pumps and they both do that. Never noticed that before. Interesting.
Offline Elan
    • Vital Motor Parts
« Reply #2 on: May 23, 2015, 05:39:54 PM »
Yeah I had thought I was missing a part at first.
76 750k
« Reply #3 on: May 23, 2015, 11:22:44 PM »
Mine did it before and after I installed Elans kit.
« Reply #4 on: May 24, 2015, 05:34:25 AM »
Thanks for the replies! I'll worry no more.
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #5 on: May 21, 2023, 09:26:38 PM »
Pushed in:
Pulled out:
I know this is an old thread, but I'm curious if anyone else's pump rotates with more difficulty when pushed in and easy when pulled out, the way mine does. Is that normal?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
« Reply #6 on: May 21, 2023, 10:04:28 PM »
There is a 'hump' in the crankcase next to the pump gear that keeps it from moving out too far in use, nudges against the middle of the gear. They all have the movement.
