Author Topic: different floats  (Read 1275 times)
Offline dusterdude
different floats
« on: May 24, 2015, 07:04:04 AM »
years ago when i bought my bike,71 750,the carbs were rebuilt by a friend of mine and he installed those black fiber type floats,these floats are a bit wide and over the years have given me fits with interfering with my bowl gaskets.are there any slimmer types of floats i can use?thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
Re: different floats
« Reply #1 on: May 24, 2015, 09:02:50 AM »
geez cal,is that the best you can do? :D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #2 on: May 24, 2015, 10:54:02 AM »
lol,you're a funny mutha
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #3 on: May 24, 2015, 01:25:51 PM »
you're welcome
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline harisuluv
« Reply #4 on: May 24, 2015, 01:40:48 PM »
Black ones better than the brass ones, brass part is now replaced with synthetic float.  It's a good thing you mentioned you have a 750 cause I know probably what the problem is.
Your buddy probably looked at the floats you have now and figured they were a match, they certainly do at first glance.  However, what I suspect is that he actually replaced your 750 floats with 500/550 floats, which are slightly WIDER.  Hence why you are probably rubbing where you shouldn't be.
Offline dusterdude
« Reply #5 on: May 24, 2015, 02:39:55 PM »
Could be,of course only god knows what they are out of,he has parts for every jap bike and brit bike ever made
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #6 on: May 24, 2015, 02:47:29 PM »
I have had black floats in a K1 for a long time after chucking the leaky brass and never had a problem. Are you using an aftermarket gasket that may be swelling or not fitting correctly ?
Offline harisuluv
« Reply #7 on: May 24, 2015, 03:39:27 PM »
Any way to tell, James? Measurements that can be taken?
I can tell by looking at them real close.  But if I'm not sure I have verified floats of each to compare and I can know for sure where it came from.
Offline harisuluv
« Reply #8 on: May 24, 2015, 03:44:52 PM »
Here is a a 750 float (top) and a 500/550 float (bottom).
They are lined up on the left, the second shot shows the total width difference.  It's about 53mm vs 55.5mm, respectively.
Additionally, they are also different part numbers.
« Last Edit: May 24, 2015, 03:49:51 PM by harisuluv »
Offline dusterdude
« Reply #9 on: May 24, 2015, 03:52:53 PM »
My damn phone wont load the pics,ill try the computer when i can.thanks
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #10 on: May 24, 2015, 03:54:10 PM »
Ek,i really dont remember where the gaskets came from but i can say the floats were replaced because the brass ones were toast
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
« Reply #11 on: May 24, 2015, 03:55:55 PM »
My phone loaded the pics,i can tell ya'll thats the difference right there.now i need 750 floats.thanks a bunch
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline harisuluv
« Reply #12 on: May 24, 2015, 05:17:56 PM »
I have those too, I can send you a set.
Offline dusterdude
« Reply #13 on: May 24, 2015, 05:25:04 PM »
How much you askin for them?
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
