Author Topic: The Replacement: CB550  (Read 11945 times)
Offline Scott S
Re: The Replacement: CB550
« Reply #25 on: June 09, 2015, 03:43:22 PM »
 It's pretty small....it necks down after the nipple on the air box and the piece you see sticking out in that photo is what we used to call the "pooter" in the VW world. It has a slit in the end and you pinch it to let the moisture out.
 The hose leading to it is ~8.9mm O.D. Good luck finding one....
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #26 on: June 09, 2015, 03:47:48 PM »
 I got the 400F bars installed. I need to get a set of my favorite grips. Also, when installing the braided stainless brake lines I discovered that the hard line and caliper body fittings were cross threaded. Luckily, I have another caliper body....but...the pad on the caliper side was wet. I'm just going to be done with it and order a new piston, seal and hard line.
 I'm a big fan of the David Silver Spares master cylinder, but the stock one is working great and not leaking, so new lines and a rebuilt caliper will do the job. That's the same set up I have on my 550F and it's fine.
 Forks will soon be removed for service and polishing. And when the wheel goes back on, it won't be a wire wheel.  8)
'71 CB500 K0
'81 Yamaha XS650
« Reply #27 on: June 09, 2015, 04:24:28 PM »
What grips?  Lesters?!
Offline onetruepunk87
« Reply #28 on: June 09, 2015, 04:40:03 PM »
Scott... looking great so far!  Question for you.... What size is the filter box drain tube?  I need to source one of these, but haven't found oem and don't know ID or length of the tube.  Thanks in advance!
Kyle
It's still available from David Silver Spares
http://www.davidsilverspares.com/CB500K1-FOUR-1972/part_61404/
Bikes looking good!
Offline Scott S
« Reply #29 on: June 09, 2015, 04:41:41 PM »
Kyle
Bikes looking good!
 Well, I'll be darned.... that one's missing the "pooter" on the end, not that it really matters.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #30 on: June 09, 2015, 04:42:46 PM »
 I love the Pro Grip 714's. And, Yes.....Lesters!
'71 CB500 K0
'81 Yamaha XS650
« Reply #31 on: June 09, 2015, 04:46:10 PM »
The Pro Grips are my fav too, just installed a set on my 550F.
« Reply #32 on: June 09, 2015, 04:48:59 PM »
I also use the Pro Grip 714s on my 750 -- very comfortable and functional.
Nice Lesters!!
Any decision on color?
Offline Scott S
« Reply #33 on: June 09, 2015, 04:58:00 PM »
 As of today, Jade Green. :)
'71 CB500 K0
'81 Yamaha XS650
Offline fastbroshi
  • Puppet
« Reply #34 on: June 09, 2015, 07:27:12 PM »
Check out how dark CB750 Cafe Fan's jade bike came out; it looks awesome.  It's in one of his more recent posts.
Just call me Timmaaaaay!!!
« Reply #35 on: June 09, 2015, 07:48:38 PM »
That stock exhaust looks pretty amazing. Does it have the baffles or have they been removed?  I imagine it sounds pretty good with a non-baffled 4-4.
Offline riverfever
« Reply #36 on: June 09, 2015, 08:43:50 PM »
So jealous of those wheels. I don't like anything but spokes normally but I really dig those. Great work on the carbs too. They turned out super clean.
Offline Scott S
« Reply #37 on: June 10, 2015, 03:41:21 AM »
 I saw that..... and I don't care for it (Sorry, Don  :(  ). I LOVE the blue bodywork he has, though.
 I'm working with a painter on getting the correct factory hue. I was torn between the green and the blue. I've seen Jade Green come out wrong too many times; too much yellow, too dark, too much flake, etc. If we have trouble getting it right, I'll switch to the blue.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #38 on: June 10, 2015, 03:44:12 AM »
 The exhaust IS nice. I had planned on a 4-1 when I built this bike in my head, but those are too nice to remove. A minor ding here and there and the usual battery acid stain on the inside, but very solid and shiny.
 Baffles are still there and they sound great.
 I've always heard you'd be hard pressed to find better performing pipes for the 500/550. Only race pipes and then only at high RPM. You only save weight. Supposedly, the stock 4-4 is a very good set up.
'71 CB500 K0
'81 Yamaha XS650
« Reply #39 on: June 10, 2015, 07:53:05 AM »
I'd love to see it in Jade Green. It will set it apart from mine and dmonday's in orange.
« Reply #40 on: June 10, 2015, 07:54:37 AM »
I've seen reproduction 4-4s to 750s but not 550s. Rare in good shape.
Offline Scott S
« Reply #41 on: June 16, 2015, 04:24:37 PM »
 This is the first CB500/550 I've had that has the stock 4-4 exhaust. Went to swap put the rear wheel today and was surprised to find out that the exhaust has to come off!
 That's OK, it gave me a chance to touch up the frame, swing arm, exhaust brackets and even clean up the hard to reach spots on the mufflers.
 I soaked the exhaust clamps and a spare set I had in a mix of naval jelly and water. Still some rusty spots, but I'll be able to pick out the four best.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #42 on: June 16, 2015, 04:27:42 PM »
 I cleaned the chain and got the real Lester installed. I tried adjusting the brake but it seems to take up all the adjustment before I get a good pedal. It was soft before, but I didn't mess with it because I knew I'd be swapping out the wheel/backing plate.
 The new backing plate has EBC shoes with only a few hundred miles on them. The pivot is installed right, dots lined up on the arm, the brake lever is the same, etc. Guess I'll just have to take the foot lever off and rotate it a couple of splines?
'71 CB500 K0
'81 Yamaha XS650
Offline mrfish2
  • I might be a
« Reply #43 on: June 16, 2015, 05:20:41 PM »
The rear wheel comes off easily without having to take the stock exhaust off, what made you have to pull the exhaust all the way off?
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Scott S
« Reply #44 on: June 16, 2015, 05:52:44 PM »
 There was no way the axle was coming out. I consulted my genuine shop manual and it said to remove the left and right exhausts.
'71 CB500 K0
'81 Yamaha XS650
Offline mrfish2
  • I might be a
« Reply #45 on: June 16, 2015, 05:57:44 PM »
Haha come on guys, none of you have simply removed the chain adjuster stops and slid the rear wheel and axle off the swingarm? That's how i did mine (if I'm remembering correctly).
1980 CB650C - Sold
Offline Scott S
« Reply #46 on: June 16, 2015, 06:01:04 PM »
 The only problem with that is I have a riveted chain. If I had a master link, maybe that would work.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #47 on: June 18, 2015, 08:12:24 AM »
 After getting the rear wheel back on and the brake straightened out, I installed the exhaust. Pretty tough to do with one person. And I only broke one exhaust stud in the process.  ::)
 Got the bike jacked up and pulled the forks. Also a little tough to do by myself, mostly because there was some rust in the left fork ear and it was holding on tight. I couldn't spread the triple clamp and pull the fork at the same time.
 I managed to get it out and I wire brushed inside the fork ears and sprayed it with rust converter. Sanded the upper forks and triple tree clamp area. I stripped the clear coat off the forks and gave the lowers a light sanding. I have a friend with a killer buffing setup and he's going to help me polish the forks (and my tappet covers while we're at it).
 I'll change the oil and add a few washers for some preload. It's hot as blue blazes here.....the forks are sitting out in the sun and, as soon as I'm sure there's no moisture left, I'll spray down the rusty areas with converter, too.
 Also cleaned up some of the caliper stuff. I have a new piston, seal and hard line sitting on the bench. Once the front end is back together I'll finish installing the braided lines and bleed the brakes.
« Last Edit: June 18, 2015, 09:59:56 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #48 on: June 18, 2015, 09:45:14 AM »
Scott,
The fork tubes obviously have some rust, but I imagine that there is no pitting in the travel area next to the lowers, and the treated oxidation will be covered by the ears.  Are you rebuilding/servicing the forks, too.  I was just wondering since they were still "assembled" and polishing the lowers can be a little easier disassembled.
Offline Scott S
« Reply #49 on: June 18, 2015, 10:01:56 AM »
 No....the travel area is fine. Seals are good. All the rust is up in the area covered by the fork ears. The lowers can be polished like this. I've done it before.
 The plan is to just change the oil and add 2 or 3 washers on top of the springs for a little preload.
'71 CB500 K0
'81 Yamaha XS650
