Author Topic: electronic ignition  (Read 1999 times)
Offline coal909
electronic ignition
« on: May 24, 2015, 07:35:32 PM »
Hey guys,
 i'm pretty new to all this tinkering so i have a couple questions. I've been having issues with my points lately, mainly the 2-3 set. I pulled  the plugs and  saw that 1-4 get a healthy spark but  2-3 gets no spark I had both sets changed last season and since then have failed  again pretty  much right off the bat this season. one of the times  i took off the cover to check my points ( when they where failing) i noticed that  some water condensation was on the inside.
should i get a new seal for my cover so no water is getting in?
and Im thinking that this would be a good time to switch to a electronic ignition(i've heard they are more reliable). i was wondering what brand can you guys  recommend and when switching to a electronic ignition do you have to change  the coils at the same time
Thanks in advance
Offline dusterdude
Re: electronic ignition
« Reply #1 on: May 25, 2015, 06:34:14 AM »
I love my pamco
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline nixon
« Reply #2 on: June 02, 2015, 05:02:55 AM »
got a dyna s with 5ohm coils - made noticeable differnce. easy install
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Offline jonnycakes
« Reply #3 on: June 07, 2015, 03:12:29 PM »
Make sure it's not the coil first. Swap the wires going from the point to the coil and see if the no spark issue follows
'Matic-Fanatic
« Reply #4 on: June 08, 2015, 07:57:11 PM »
Check the coils and go with PAMCO. I had a Dyna crap out on me and their attitude turned me off them. Pete stands behind his product.
« Reply #5 on: June 09, 2015, 04:48:28 AM »
I love Pamco, great product.
Also there is Hondaman's electronic ignition, used by many happy customers:
http://sohc4shop.com/catalog/product_info.php?manufacturers_id=12&products_id=32
Offline jukku
  • Happy with my Hondamatic
« Reply #6 on: June 09, 2015, 01:26:33 PM »
I have Boyer Bransden and it working well. Electronic ignition advance!
