Author Topic: 73 CB500 Boston Cafe  (Read 8691 times)
Offline lajos
Re: 73 CB500 Boston Cafe
« Reply #50 on: June 26, 2015, 07:30:24 AM »
I started stripping paint off the cylinders with aircraft stripper and soon realized that it's just not going to work. Not sure if Honda used a different paint  than the crank case or if the paint burned on there from the heat, but the stripper hardly softened it. I also found it near impossible to get between the fins even with small tube brushes to scrape the paint off. And it was way too messy.
I decided that it was time for soda blasting as Cal suggested. I picked up a 15lb soda blaster from HF along with a bag of medium size soda media.
I've seen people complain about this soda blaster that it's a PITA to load through the 1/4" hole, so I also got a 1.25" black pipe and cap. Cut a hole on the tank and welded in the pipe that allows soda to be poured in straight from the bag. Painted the top with flat engine paint for color testing (that's the color that goes on the cylinders).
Damn this thing works amazing. I only wish I would've gone this route earlier. I cleaned up the cylinders, head and all carb bodies in an hour. I didn't have time to take pics of the parts because I was racing to get it done before a rainstorm moved in, but they came out amazing. Now on to paint prepping those parts.
'73 CB500 frame with '76 CB550 engine build in progress http://forums.sohc4.net/index.php/topic,148166.0.html
'09 Ducati M696
Offline lajos
« Reply #51 on: June 27, 2015, 07:38:34 AM »
Weather looked good today so the plan was to paint. But two studs on the carb side didn't come out of the head, one broke. Seems like groundhog day.
This time however washer and nut got welded, oxy mapp heated stud, whacked and liquid wrenched, and got both out in an hour. (Cal should write a book. I learned to just do what he says.)
'09 Ducati M696
Offline lajos
« Reply #52 on: June 28, 2015, 07:46:00 AM »
Haha. Wives are different. The only option is to compromise.
'09 Ducati M696
Offline lajos
« Reply #53 on: July 05, 2015, 05:33:42 PM »
The wife gave me the day off so finally had time to paint a bunch of engine parts.
'09 Ducati M696
Offline lajos
« Reply #54 on: July 30, 2015, 01:59:36 PM »
The engine is finally going back together!
My kids' summer vacation is taking a toll on my free time, but I try to work on it a bit every day.
I don't have much bench space so made an engine stand that holds the bottom crank case.
I have the kick starter and transmission gears in. Hope I put it together correctly, wish I would've taken a lot more pictures when I took it apart. The gear shift forks are soaking now, I'll test the gears when that's back in.
'09 Ducati M696
Offline lajos
« Reply #55 on: August 07, 2015, 11:22:11 AM »
Built the shift forks earlier this week and checked the transmission. Did a quick test and seems to be shifting through all gears.
Put the crankshaft in today. Plastigaged the connecting rod journals, all check out below 0.0015". The crank bearings on the ignition side had a lot of pitting, but I couldn't find any new yellow ones. Salvaged green ones from the extra cb500 engine I have, the plastigage strip matches the other bearings pretty closely.
Timing chain is brand new, primary chain is reuse (couldn't find new one,  but it seems fine).
'09 Ducati M696
Offline lajos
« Reply #56 on: August 13, 2015, 09:58:25 PM »
Waiting for some orings and seals from partzilla before I can close up the crankcase, so finished cleaning the carbs and put them back together. The needle pins were in the second notch from the bottom. I moved them to the bottom position assuming that the 600cc kit will need more fuel. Hope that wasn't a mistake because it looks like adjusting the needle position is a major pita.
Wish I had a better before picture.
'09 Ducati M696
Offline lajos
« Reply #57 on: August 14, 2015, 10:08:48 AM »
Thanks for the advice, Cal. I'm using stock camshaft, so there won't be more air, makes perfect sense to not add more fuel. I am planning pod filters though.
I have put the needles back to where they were when I took the carbs apart, which is 2nd notch from the bottom. It actually wasn't too bad, took less than an hour now that I know where all the screws and springs and whatnots go.
'09 Ducati M696
Offline lajos
« Reply #58 on: August 25, 2015, 12:01:40 PM »
I finally got the o-rings from partzilla, so I finished putting the bottom end together.
I didn't know that the hondabond is as thick as it is, it was a challenge even squeezing it through the applicator attachment. I put it on as thin as I could and wiped it off around the crankshaft bearings to make sure not to plug them up. A little bit still squeezed out around the case.
Next, I misread the torque spec for the 6mm flange bolts and I ended up stretching the 105mm bolt that goes up from under the oil pan.  Good thing I stopped before it snapped and revisited the manual. Also sent a mental thank you to the honda engineer who made that bolt stretchy and not the crankcase thread strippy. Since I started with 2 dead engines I had an extra 105mm bolt.
I wanted to prime the oil passages and the best I could come up with was to strap the connecting rods with rubber bands to a bar above the engine and turn the crankshaft by hand with the alternator bolt. The oil didn't come at first, so I removed the oil pressure sender that helped the pump pick up the oil.
I know the engine is still ways away from (fingers crossed) running, but hearing the oil gurgle through the crank bearings for the first time totally made my day.
Next up is putting the pistons and cylinders on. I've chased the cylinder stud threads and have the APE studs to go on.
Question about the base and head gaskets. The package for the base gasket (NE brand) says no lubrication or sealer necessary for the gaskets. I've read many posts on this forum and found no consensus if it should be dry, oiled, hondabonded or gasket sealer sprayed. Should I just install them dry as the package says?
'09 Ducati M696
« Reply #59 on: August 25, 2015, 12:19:37 PM »
Nice con-rod keeper/contraption!
Offline Trad
« Reply #60 on: August 25, 2015, 12:19:49 PM »
I have the 61.5mm cruzinimage pistons from ebay. The cylinders were bored to those with 2 mil clearance.
Really nice work on the build so far; Excited to see it come together. I just wanted to make sure you meant 2 thou and not two millimetres? Two mil will be far too much clearance for those cast pistons. 2 thou piston to wall clearance would be a proper spec for that setup.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline lajos
« Reply #61 on: August 25, 2015, 01:16:39 PM »
Thanks for checking, I sometimes have trouble with the terminology ;) The cylinders were bored to .002" clearance, so 2 thousandth of an inch, not millimeter.
The pistons fit nice, not too snug. If I have time tonight I will install studs, pistons, and test fit the cylinder block.
'09 Ducati M696
Offline lajos
« Reply #62 on: August 26, 2015, 09:52:30 PM »
Installed the APE studs, pistons, rings and the cylinders.
I got hose clamps to compress the rings because the piston ring compressor I got was way too tall, but ended up just using my fingers to slide the rings in one at a time. There is enough bevel left at the bottom of the sleeves to guide the rings in.
I wish I would've trimmed the base gasket, it matches well in the front but sticks out a bit in the back. I don't want to pull the cylinders off, I'll have to figure out how to do it without messing up the paint. But lesson learned for the next build.
Tested the coils that were on the bike, but they are toast. The input side has the right resistance, but no or very little spark comes out on the other side when I tried them with a battery. Ordered Dyna 5ohm coils.
'09 Ducati M696
Offline lajos
« Reply #63 on: September 01, 2015, 04:18:34 PM »
I blew a head gasket. Or more like wasted it.
As can be seen on the last picture from my previous post I put in the cam chain guide backwards. I only noticed when I tried to intall the camshaft in so had to take the head back off. Luckily I ordered an extra head gasket when I got the 600cc kit ;)
Other than that, putting the top end back together went easy.
Adjusting the valve tappets took longer than expected, there's not a lot of space to slide the feeler gauge in there.
For the ignition I first put the new Daiichi points in, but I had a hard time setting the ignition. I had to gap the points way over 0.4mm to get the timing to the F marks. I found a post by Hondaman suggesting to cut the slots wider on the base plate with these points. I'm not ready to do that yet so I'm reusing the original TEC points that were on the CB500 engine (the CB550 motor had no ignition timing cover on it so the ignition parts and advancer rusted beyond repair).
The alternator coils still need to be cleaned up, but otherwise I'm ready to find out if this thing will fire up or did I just make a very heavy paperweight...
I'll rig up some temporary wiring and this weekend I'll try to hook this thing to a car battery and see what happens.
I'm going to use the old exhaust and intake studs (there should be enough that came out in one piece from 3 heads). Still, they are pretty rusted. Are there better studs available for these engines?
'09 Ducati M696
Offline lajos
« Reply #64 on: September 01, 2015, 06:22:44 PM »
Thanks for the reminder to retorque the head. I wouldn't have known to do that. I'll pull the valve cover and retourqe them(didn't hondabond the pucks).
I'm using all ignition parts, TEC plate, TEC points and advancer from the extra CB500 engine (condensers are new). I think they cleaned up good and also bought an extra CB550 advancer from ebay (hasn't arrived yet). If these don't work out I might be coming to you for your extras ;)
I've torqued the head to 18.5 ftlbs because I've seen posts here that some APE studs broke at 20ftlbs (recommended by APE). Is the 18.5 tight enough or should I go higher?
'09 Ducati M696
Offline lajos
« Reply #65 on: September 03, 2015, 11:21:35 AM »
So I tested the two original oil pressure senders that came with the engines and both were toast.
Honda still has a compatible part for $30, but it would be a special order.
After some research I found that many Japanese cars use the same 1/8"-28 BSPT threads. I went to the local car parts store and bought this switch for a '99 Mitsubishi Eclipse, cost $8. It's a bit taller, but it seems to fit (I realized I didn't have the left side cover, it's on order from ebay). Same connection on the top, even uses the same screw.
'09 Ducati M696
« Reply #66 on: September 03, 2015, 12:38:07 PM »
Since you have the old studs out (the hardest part), I'd replace them with new ones to match your new looking motor!
Offline lajos
« Reply #67 on: September 05, 2015, 10:50:10 AM »
I will get new studs, partzilla has at least the exhaust ones. The intake studs I have are actually in good shape, no rust.
I wired up my temporary ignition panel. Got kill switch spark and a red button. Now I need to find a bigger battery, a bottle that holds some fuel, hook up what's left of my exhaust header, and tomorrow I'll stand back...
...and press the red button.  8)
'09 Ducati M696
Offline lajos
« Reply #68 on: September 06, 2015, 09:59:32 AM »
There's good news and bad news.
It started up! In fact it fired right up and sounded freaking awesome.
Now the bad news. Oil pressure is too high. I had an oil pressure gauge hooked up at the pump where the pressure switch goes, which I was not keeping an eye on cause I was too excited. But soon it spewed oil out at the oil filter gasket.
I put the gasket back in, started it to idle, and the oil pressure shot off the chart (in fact I think I blew the oil pressure gauge, it doesn't return to 0 no more).
Before I put the head on, I primed the engine with oil and I know there was oil in the passages that goes up to the head.
After I put the oil filter back on I heard slurping noises for a second from the head, so I'm assuming there's oil up there, but I'll pull the valve cover to check.
I'm using Shell Rotella 15-40 dino oil.
Any ideas what could be happening? There seems to be an oil pressure regulator in the pump, some oil pressure safety thing in the oil filter, and of course it could be some blocked oil passage somewhere.
'09 Ducati M696
Offline lajos
« Reply #69 on: September 07, 2015, 12:18:19 PM »
Figured it out. Oil pressure relief valve was stuck because of user error. These two oil passage caps might look the same but on closer inspection one has a groove for the spring. Since I used the wrong one the spring was over compressed.
Now I got great oil pressure.
'09 Ducati M696
Offline lajos
« Reply #70 on: September 07, 2015, 12:26:51 PM »
Here's a short video of what it sounds like with whatever I have left from the old headers (not much).
Please ignore the broomstick, the wifey was not available to hold the fuel bottle  ;D
'09 Ducati M696
