Author Topic: RE: Need new Zerk fittings swing arm  (Read 823 times)
Offline chewbacca5000
  • I polish covers!
« on: May 27, 2015, 07:22:35 PM »
My grease fittings were clogged so I pulled them out and need new ones.  I want to drill and tap new standard sized ones in.
What fitting?
What drill?
What tap?
Much thanks.
Offline Davez134
Re: RE: Need new Zerk fittings swing arm
« Reply #1 on: May 27, 2015, 07:32:42 PM »
I used:
1/4"-28 zerk from autozone.
1/4"-28 tap
7/32 drill
  • I polish covers!
« Reply #2 on: May 27, 2015, 07:33:47 PM »
I used:
1/4"-28 tap
7/32 drill
Thank You.
  • I polish covers!
« Reply #3 on: May 28, 2015, 07:30:55 AM »
I used:
1/4"-28 tap
7/32 drill
Thanks got drill, tap, and fittings for $9 at local hardware supplier.
Offline Davez134
« Reply #4 on: May 28, 2015, 07:56:22 AM »
Nice!
Offline gregripko
« Reply #5 on: May 28, 2015, 08:07:49 AM »
Type of bike? Need to do the same for my cb550
Offline Davez134
« Reply #6 on: May 28, 2015, 08:51:05 AM »
You can tap for any size you like, obviously as long as it's a bigger diameter than the hole for original fitting. 1/4"-28 just seems to be a common, readily available size.
  • I polish covers!
« Reply #7 on: May 28, 2015, 09:13:12 AM »
I used:
1/4"-28 tap
7/32 drill
This worked beautiful!  Thanks man!
  • I polish covers!
« Reply #8 on: May 28, 2015, 09:16:30 AM »
I got a 750, but should work well with other years as well.  The 1/4"-28 Zerk is a great size.  It makes such an awesome seal that I have to use needle nose pliers to get the darn thing off.  Well worth the time to do the mod.
