Author Topic: Cam options for cb500 650???  (Read 2228 times)
Offline Calisoul
« on: May 27, 2015, 09:31:57 PM »
Hey everyone!
I've got the head off of my 73 cb500k. in the process of porting and re-ringing. I basically just need to pop it back in. I figured while I was in there I would look into a cam upgrade.
I've heard that a 650 cam would give me some extra HP and is an easy swap. Has anyone done this?
These are my questions:
Will this work?
what CB650 years/ models will work?
what needs to be done besides just popping it in there?
Will this actually give me more power?
Thanks for any help guy
Offline calj737
  • I refuse...
Re: Cam options for cb500 650???
« Reply #1 on: May 28, 2015, 04:17:18 AM »
It will work. It is easy. There's a cam and tach gear (required) for sale by HellRaiser on the Parts For Sale section. You need the cam gear because the ratio differs from your 500/550. It will add some oomph to your stock motor.
Reuse your stock cam sprocket and chain.
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: May 28, 2015, 04:22:41 AM »
A 650 cam will definitely wake your 500 up however it's been a popular swap and 650 cams are getting harder to find and more expensive because sellers know they are popular with the 500/550 owners. You can use the 650 cam as it is however your tach won't be accurate because the 500/550 tachs have a different ratio than the 650 so you will need the tach drive from a 650 as well as either a 650 or 750 tach. You're also rolling the dice purchasing a used cam because it may already be severely worn.
I dropped a 650 cam in my 550 and it did wake it up especially at 6k and higher rpm however if I were to do it again I'd get a new cam from say Web cams, they're not cheap but once I added up the cost of finding a good used 650 cam, purchasing the 650 tach drive and another tach when added all up I didn't save all that much. On the other hand if I had purchased a new cam from web cams the cam itself would already be for a 500/550 so there wouldn't have been a need for the 650 tach or tach drive.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline calj737
  • I refuse...
« Reply #3 on: May 28, 2015, 04:34:32 AM »
Bailgang - aren't WebCams hardwelded? If so, you'd need to replace your rockers too with hardwelded units... That certainly exceeds the price of a cam gear and tach gauge. I agree with your perspective about used cams, I won't ever buy another after getting hosed by a seller previously. And I certainly would only buy a used cam if they sold the corresponding rockers for that cam with the purchase.
But many do, and many are pleased with the results...
Offline Bailgang
  • Scott
  • Indiana
« Reply #4 on: May 28, 2015, 04:40:19 AM »
I know they'll take your existing cam, hardweld it then regrind it but I wasn't aware that hardwelded rockers would be needed as well. That's a good point that I was unaware of.
Scott
71 cb350 twin
77 cb750 F2
Offline Tews19
  • I am no
« Reply #5 on: May 28, 2015, 07:38:33 AM »
Hellraiserxl has another 650 cam for sale. PM him.
1970 Honda CB750 survivor.
« Reply #6 on: May 28, 2015, 07:42:10 AM »
Gone!
Offline Tews19
  • I am no
« Reply #7 on: May 28, 2015, 07:44:49 AM »
He has another that he is selling for 140 iirc.
Offline Calisoul
« Reply #8 on: May 28, 2015, 10:49:07 AM »
So does every model and year of the 650 work?
I thought about the cam being worn but if the seller has any kind of warranty or exchange I think it would be worth the $100/$150.
Thanks for the suggestions guys!
Offline Tews19
  • I am no
« Reply #9 on: May 28, 2015, 11:21:37 AM »
Last post, do you mean you think a 500 cam that you have is worth 100/150? If that is what you are asking..... Um no. No one offers warranties. No much possible install issues on the buyer if they somehow messed up installation
Offline mrfish2
  • I might be a
« Reply #10 on: May 28, 2015, 11:21:49 AM »
The only cams that work are from 79 to 82 CB650's, which are SOHC. In 83 Honda switched the 650 over to DOHC.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #11 on: May 28, 2015, 12:12:57 PM »
Be careful to check the condition of the lobes on the camshaft for pitting and excessive wear.
