Author Topic: Putting tank Logos back on?  (Read 6138 times)
Offline GizmoDuck
« on: May 31, 2015, 10:56:48 AM »
Any tips for putting the tank logos back on?  I have a 1973 CB350F.  The little tank inserts were rusted to pieces and fell apart once I got the logo removed.  Painting the tank then want to put the logo back on and not sure if I should file down the pins and use tape or if someone makes replacement inserts that the pins go into.   Same question for the side cover logos.
Offline Vinhead1957
Re: Putting tank Logos back on?
« Reply #1 on: June 02, 2015, 05:22:59 AM »
You can leave the pins on and cut a hole in body side moulding tape available at any auto parts store. The 3M tape is a clean install and doesn't interfere or chip paint. Use the pins to line the logos up and voila!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: June 02, 2015, 06:53:01 AM »
The little clips are still available from Honda:
87311-634-600
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline GizmoDuck
« Reply #3 on: June 02, 2015, 04:55:30 PM »
87311-634-600
Where should I try to order those from?
« Reply #4 on: June 02, 2015, 05:08:29 PM »
Offline GizmoDuck
« Reply #5 on: June 02, 2015, 05:12:07 PM »
87311-634-600
http://www.ebay.com/itm/NOS-HONDA-87311-634-600-NUT-EMBLEM-CLAMP-/191098830214
Thanks!  Where should I go looking for original part numbers so I don't have to bug people on the board about it anymore?
« Reply #6 on: June 02, 2015, 06:26:47 PM »
87311-634-600
Here is one place...
http://www.westernhonda.com/fiche_select1.asp?cat=Motorcycles&mfg=Honda
