Author Topic: Cam timing marks missing?  (Read 1256 times)
Offline Moffman
  • 1979 Honda CB650
« on: May 31, 2015, 03:32:15 PM »
I feel like I'm asking a lot of questions but I'd really like to not have to tear into this again so I want to make sure everything is spot on. Anyway I can't seem to find the punched timing marks on the cam sprocket that the manual says should align with the deck of the head. There is a notch in the crank that aligns with the right side of the deck on the right side of the engine but on the left there should be those two marks.
Am I looking in the wrong spot? (79 CB650)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Cam timing marks missing?
« Reply #1 on: June 01, 2015, 08:34:38 AM »
The notch in the end of the camshaft (first pic) should point FORWARD along the deck of the head when the advancer plate is set to 1/4 TDC.
DO THIS FIRST.
Then you walk the chain/cam sprocket around till it aligns with the bolt holes in the camshaft.
It looks like you have everything set correctly, as long as this matches with 1/4 TDC on the advancer plate.
Is it an aftermarket cam? Maybe it doesn't have all the marks? The big notch is most important.
« Last Edit: June 01, 2015, 09:28:20 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline mrfish2
  • I might be a
« Reply #2 on: June 01, 2015, 09:01:28 AM »
The notch in the end of the camshaft (first pic) should point UP (perpendicular to the flat sections of the shaft bearing seats) when the advancer plate is set to 1/4 TDC. DO THIS FIRST.
Are you sure about this? On the 550's the notch should point towards the front of the bike, just like he has it set and seeing as the 650 motors are nearly identical to the 550 motors then there shouldn't be a difference.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline evanphi
  • Apparently I'm an
« Reply #3 on: June 01, 2015, 09:24:57 AM »
Good catch. Edited!
--Evan
Offline Moffman
  • 1979 Honda CB650
« Reply #4 on: June 01, 2015, 10:00:15 AM »
Triple checked it was at 1.4 TDC, aligned the cam slot to head and the sprocket to the marks where it was before. What's weird is the Clymer manual mentions the punch marks but the other online service manual I have that looks like its factory doesn't. The top end was never apart before me so maybe they starting after '79? Bizarre but I think it's good, thanks guys.
