Author Topic: 77-78 cb750F wheel assembly question  (Read 887 times)
Offline 76four
« on: May 31, 2015, 05:46:41 PM »
After looking at a couple rear wheel diagrams for the 77-78 cb750 F there seems to be a slight difference that has me puzzled.  I am trying to reinstall my bearings/seals etc. One diagram shows what appears to be a bearing retainer labeled (#5) on diagram on the sprocket side and another diagram shows no (#5) retainer on the sprocket side but shows it on the other side of the wheel.  Unless there is a difference between the 77 and 78 model years. Looking over the diagrams it appears that the 78 had this (#5) retainer on the sprocket side while the 77 has no retainer on the sprocket side but on the other side.  Is one of the diagrams wrong or is it just a slight difference on account of the year? The first picture is the 77 diagram and the second picture is the 78. Third picture diagram is labeled 77 and shows the (#5) retainer on the disk brake side. Looking for some direction thanks in advance.
« Last Edit: May 31, 2015, 05:50:22 PM by 76four »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 77-78 cb750F wheel assembly question
« Reply #1 on: May 31, 2015, 06:26:53 PM »
Only one side of the hub will be threaded for this retainer. Put the retainer on that side of the hub...  ;)
My money is on the brake side.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Wobbly
« Reply #2 on: June 01, 2015, 03:47:16 AM »
Offline 76four
« Reply #3 on: June 01, 2015, 12:09:18 PM »
Thanks for the info and help guys I appreciate it.
