Sorry for all the simple questions..
As you can see in the picture below there is no tension on the throttle return spring (PD42A carbs so circular spring).
As far as I can tell from my pictures the spring sits in the orientation it's in, hooked on the bracket attached to the throttle shaft on one side and the thin wall on the carb body on the other.
Is this correct? And if so how do I get tension on that spring? Am I supposed to twist the entire shaft around once to essentially preload it?
Thanks!
