Author Topic: 1972 CB350 For the Daughter  (Read 65223 times)
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: 1972 CB350 For the Daughter
« Reply #425 on: May 26, 2017, 10:29:23 AM »
My wife doesn't get angry over that sort of stuff.  The tank is nice and clean.  Now if it had been dirty then it would be a different story.
Got the color issue fixed easily on the registration.  The powder coater finally replied to my multiple, texts and phone messages.  He is supposed to coat the brake rod today so I can pick it up tomorrow, but I have heard that story before so I am not holding my breath.  Also talked with my painter yesterday.  Hopefully I will have the front fender and exhaust tomorrow as well.
I was putting it off (for some unknown reason), but I mounted the tank yesterday and ran the fuel lines.  Putting the quick disconnect on is always a major PITA.  Put the side covers and seat on as well.  I really like how everything looks together.  I adjusted the rear shock height, but I still need to drop the forks in the triples a bit.  Right now the bike sits level, but I want the front to be a tiny bit lower than the rear.  Mirrors will be here today so those will get fitted as well.  So once I get the couple of parts I should be down to installing the chain, bleeding the brakes, and going over the bolts to make sure everything is snug.
Offline Harsh
« Reply #426 on: May 26, 2017, 02:57:08 PM »
So it was pointed out that I was a bad person for not posting a pic
Dropped the forks in the trees 1/4".  I think I might need to go a bit more, but I will wait until I take a test ride.
So as we sit...minus the brake rod, exhaust, and front fender.
Offline irish44395
« Reply #427 on: May 26, 2017, 03:11:08 PM »
Thats a nice looking bike
Pete
« Reply #428 on: May 26, 2017, 03:14:47 PM »
Creamy goodness!
Offline Harsh
« Reply #429 on: May 28, 2017, 04:43:52 AM »
Thanks everybody.  It isn't finished yet, but it is close.  In a strange turn of events I picked up the brake rod yesterday.  Got all of that mounted and installed the chain.  Now if I could just get the front fender and exhaust back from the painter I would be set.
Offline Smudgemo
  • Maker of Stuff
« Reply #430 on: May 28, 2017, 10:01:00 PM »
I dig it.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline Harsh
« Reply #431 on: May 29, 2017, 02:26:07 PM »
Managed to get everything mounted today.  It did not go super smoothly though.  First I snapped a bolt in the lower triple.  Then when trying to remove it the easy out broke.  So I had to find a new place to mount the horn.  Overall it is pretty much in the same location, just the mounting point changed.  That also meant the support mount for the front brake line had to be changed as well.
Bleeding the brakes took forever.  I was having a very hard time getting fluid to go through the master cylinder.  Once it did the rest was easy.  The first test ride didn't go so well.  The bike fired up easily enough, but I could tell it was only running on one cylinder.  The left side wasn't firing.  I checked for spark and had none.  So off comes the tank to check the wires at the coils.  Sure enough one of them had popped out of its connection block.  Put it back in and secured it so it won't pop out again.  Put the tank back on and fought with the damn crossover tube for a while.  Man I hate that stupid thing.
Off for the test ride.  When I first started out the mid range of the rpm's it was a bit sluggish and it was cutting in and out a bit like it wasn't getting fuel.  Said the hell with it and went on the highway anyway.  Cruising around I could feel the bike surging a tiny bit.  However, that slowly went away after a bit of riding.  When I got off the highway the cutting in and out at mid rpm's was gone as well.  Now when at a stop I have to give it a tiny bit of gas to keep it from stalling which I didn't have to do before.
The clutch needs some adjustment and so do the foot controls.  Both tires felt a bit slippy, but the front was very slippy.  I don't know if it was the mold release, too much air, or a combo of both.  Whatever it is, it certainly does not inspire any confidence.  The front brake isn't as strong as I thought it would be either.  It works well, I just expected a bit better feel and power from the dual piston caliper and master cylinder.  Maybe after some more bedding in time it will start to feel better.
Now comes all of the adjustments and tweaks & peaks to get it running and handling better.  I still need to go back through and re-check the valve lash.  I am almost certain the right exhaust valve is a bit too loose and is making the ticking sound.
« Last Edit: May 30, 2017, 03:52:46 AM by Harsh »
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #432 on: May 29, 2017, 06:57:47 PM »
amazing work.
cb750 k6 - ugly
Offline jgger
« Reply #433 on: May 29, 2017, 07:19:52 PM »
I have been following this build, but keeping my mouth shut, it's time to chime in. Very nice job and it looks like all the hard work has paid off. The burning question........does your daughter like it?
I can only dream of having the time and patience to build like that! Great job!
Offline Harsh
« Reply #434 on: May 30, 2017, 03:54:23 AM »
Thanks, and my daughter loves it.
« Reply #435 on: May 30, 2017, 07:57:31 AM »
Harsh,
Does you daughter have much riding experience (or is this her first bike)?
Offline Harsh
« Reply #436 on: May 30, 2017, 08:10:13 AM »
This is her first bike, but she is signing up to take the MSF course and will use one of their bikes for the class.  After that she and I will slowly work on getting her going.  Yah I do things backwards.  Build something nice then teach a person how to ride it.
« Reply #437 on: May 30, 2017, 11:18:06 AM »
Hopefully, you have something less nice for her to practice on. Almost every newbie accidentally tips over their first bike.  This one seems to nice for that kind of exposure.
Offline Harsh
« Reply #438 on: May 31, 2017, 05:00:56 AM »
I am looking for a small beater bike.  Something I don't really care if it gets dropped and can stay outside since I have run out of room in the garage.
Offline Harsh
« Reply #439 on: June 13, 2017, 06:49:36 AM »
Well I am back from my trip to the mountains.  I would like to report that the bike ran great, but that just wasn't the case.  The mid range was horrible.  It would spit and sputter like it wasn't getting fuel.  Not sure at what RPM level it would start, but it would run crappy up to 7,000 rpm.  After I rolled past that it was like the bike came alive and would race to redline and run very smoothly.  So it looks like I need to get back into the carbs.  I need to find the diagram of what jets do what and at what rpm/throttle position.  I re-used the brass when I rebuilt them, but used new oem O-rings.  Because of the stumbling I couldn't get into and through the corners as I would have liked so my pictures are kind of boring.  A friend of mine did take this sweet picture for me though.
Going up
Coming down
« Last Edit: June 13, 2017, 10:50:02 AM by Harsh »
« Reply #440 on: June 13, 2017, 07:46:42 AM »
Well, I see this is going to be nominated for BOTM,  had I known the weekend I would have came down to meet you and shake your hand...  Guess I should have asked.
Bike is gorgeous!  You did fantastic work Harsh.  Daughter should be tickled pink as I am sure she is.  Hope she gave you a hug hug and big kiss on the cheek.
Time to buy a box of plugs and do a bunch of plug shops or spend some money on the dyno.  The later works really well as they can read the AF mix to get it dialled in, provided they are good at their craft.
Look forward to hearing a good report. Is it quiet enough?  Most go with the short cones and I like the sleeper approach as the longer cones have a nice report/sound when opened up, just not as gutteral and low as the short cones.
« Reply #441 on: June 13, 2017, 09:31:44 AM »
I will nominate it for August, maybe you will have a fighting chance...this month is some pretty tough competition between those 3 bikes.
David
« Reply #442 on: June 13, 2017, 09:37:53 AM »
David
I was thinking the same.  There's no technical limit to the number of candidates but there are already FOUR in the running (Scott S, flatlander, Frode2 and greenjeans) for July BOTM.  When you get a larger number of bikes, a winning bike doesn't need too many votes.
Offline Harsh
« Reply #443 on: June 13, 2017, 10:57:28 AM »
Trust me when I say I am humbled that you guys think this is nomination worthy of BOTM, but did something change in the rules?  This is only a 2 cylinder bike.  However, I guess one could skirt by rule #7 since it does have 4 valves.
« Reply #444 on: June 13, 2017, 11:34:08 AM »
Bummer!  I had a lapse into thinking it was a 350F.  Unfortunately, it is ineligible for nomination.   :(
Offline Harsh
« Reply #445 on: June 13, 2017, 11:36:33 AM »
Well if the community wants to vote for something I was nominated for photo of the week at Deals Gap and I need your help and votes to win. All you have to do is click the like button. You can vote using every device you have. I am the 7th photo down on the right (black leathers on a light green bike).
Vote early and vote often please. http://www.129photos.com/
« Last Edit: June 13, 2017, 11:49:16 AM by Harsh »
« Reply #446 on: June 14, 2017, 02:19:41 PM »
I think you have a some stiff competition -- fourth row down on the right -- yellow Grom rider stroking a purple dildo mounted to his front fender.   :o :o :o :o :o
Offline Smudgemo
  • Maker of Stuff
« Reply #447 on: June 14, 2017, 02:32:55 PM »
Yeah, those MSF trainers are awesome.  I think mine was a custom in the making - it had a sweet knee dent on the left side of the tank and I'm sure the builder was going to do the right side soon...  ::)
On a serious note, great bike.  I really like how it turned out.  My 12YO is already eyeing up my restored 550 wondering how old she needs to be.  I think a project like this would be a much better starter.
-Ryan
Offline Restoration Fan
  • My wife will never call me
« Reply #448 on: June 15, 2017, 03:36:53 PM »
Nice double entendre there, Don!
« Reply #449 on: June 15, 2017, 04:20:11 PM »
At least Harsh is beating "Stroker" Grom in the votes.
