when you post pictures of the plugs, we need to see down into the tips. Side view is not enough info.
A plug chop does not mean 'ride around for a bit' and then see what color the pugs are.
This tells you nothing.
Your carbs are comprised of several fuel delivery systems. Each system engages at different throttle positions. The systems also overlap....depending on your throttle position. Your spark plugs collect detonation deposits, and can give you an idea of what might be occurring inside your combustion chambers.
If you just ride around, you are collecting these deposits from many throttle positions, and many jet overlaps.
Your test needs to consist of a new.set of plugs, and 3-5minutes of a specific throttle position while the bike is under load, to collect deposits for that specific fuel delivery part(jet), so you know what change to make.
