Author Topic: serious white smoke after big bore  (Read 16640 times)
Offline DMcD
Re: serious white smoke after big bore
« Reply #50 on: August 09, 2015, 02:21:44 PM »
Hondaman, just out of curiosity can you clarify for me, if 0.001 clearance means the bore is 0.001 bigger than the piston, or is the bore 0.002 larger than the piston, to allow 0.001 clearance all around?
Thanks DMcD
Offline TurboD
« Reply #51 on: August 09, 2015, 03:05:59 PM »
.001 clearance means the bore would be .001 bigger than the piston.
« Reply #52 on: August 09, 2015, 03:47:11 PM »
Thanks DMcD
Thats correct, the .001 gap is all round the piston, so if you were to push the piston hard up against one side of the bore{without rings on} there would be a .002 gap on the other side, this is what you meant isn't it..?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #53 on: August 09, 2015, 05:06:46 PM »
Thanks DMcD
Excuse my previous grammar, they weren't so much arguing about how to measure, but whether (for example) a 4" piston specced to have 0.002" clearance would mean a 4.002" bore to have 0.002" at one side, or a 4.004" bore to allow 0.002" all around.
Both argued they were right, and had been building engines for many years, and teaching others to do so.
Even engine builder's can't agree!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline DMcD
« Reply #54 on: August 09, 2015, 11:37:59 PM »
 ;D
If you want an opinion, the internet is the place to get it!
Offline johno
« Reply #55 on: August 10, 2015, 03:27:55 AM »
Their may be opinions on what is an optimum clearance, but any qualified automotive engineer in the universe will know there is only one way to determine piston clearance.    If the method was debatable there would be total confusion all over the world at machine shops , car and bike factories etc alike..........as far as I'm aware there is no world confusion so there must only be one way  :o ;)
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline NickO
« Reply #56 on: August 10, 2015, 04:29:18 AM »
I assume by the above, you mean ØBore - ØPiston = Clearance (i.e. 0.001")?
Offline Jim F
  • go baby go
« Reply #57 on: August 10, 2015, 04:41:18 AM »
.001 total clearance or .0005 per side
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline TurboD
« Reply #58 on: August 10, 2015, 05:09:34 AM »
There is no opinion to this... A .001 clearance means that you have a cylinder that is .001 larger than the piston. Any and every machine shop or race engine builder that I have ever talked with in my 40 years of building race engines has always measured this way.
Offline joe p
« Reply #59 on: August 10, 2015, 06:21:54 AM »
Jim F and TurboD are perfectly correct.
« Last Edit: August 10, 2015, 06:24:08 AM by joe p »
« Reply #60 on: August 10, 2015, 06:45:45 AM »
That has always been my understanding.  8)
TAMTF...
Wilbur
Projects:
Offline Jim F
  • go baby go
« Reply #61 on: August 10, 2015, 07:51:17 AM »
yes yes yes and another yes
if they are worth there salt, they should know what this is
Jim
« Reply #62 on: August 10, 2015, 11:43:25 AM »
Good to clearify the piston vs bore clearance. One confusing part for me is the inch vs mm. The clearance has small numbers so .001 total clearance or .0005 per side
--> will be the numbers in " x 25.4mm
--> .0254mm total clearance or .0127mm per side.
Some additional hone will make it too wide rather quick, right?
I did not meaure the bores at my last rebuild. Found NOS  65mm cast pistons to replace my old working 65mm. Honed with flex hone 240 grit and done! No smoke or oil smoke nor smell when driving, acceleration or heavy deceleration.
I reused the old pistons 3 piece oil rings when the NOS ring was 1 piece...
Offline Jim F
  • go baby go
« Reply #63 on: August 10, 2015, 12:56:42 PM »
another thing you have to be careful of is that, The tighter the clearance you have,
the better the honing needs to be as far as keeping the bores dead straight.
just another 2 cents to think about.
\Jim
Offline DMcD
« Reply #64 on: August 10, 2015, 02:30:31 PM »
Cheers everyone for clearing that up for me, makes more sense now, so my 0.002 clearance will actually mean there is only 0.001 between the piston and bore during operation.
Looking forward to work tomorrow, to bore my colleagues with my new-found knowledge. ;)
« Reply #65 on: August 16, 2015, 11:28:23 AM »
Sadly, I can name one in Denver who doesn't think this way...
...some people's kids...
Offline Big Jay
    • CBRzone
« Reply #66 on: August 16, 2015, 11:42:13 PM »
.001" total clearance on an ART style cast piston is fine. Have done hundreds of them. I think the OP had an oil ring expander overlapped.
