Author Topic: CB750 K4 Axle issues  (Read 6195 times)
Offline Garage_guy_chris
Re: CB750 K4 Axle issues
« Reply #25 on: June 07, 2015, 11:06:26 PM »
I think I see the problem Im only counting a 4 bolt circle holding the brake rotor on! Which means that isnt a 750 front wheel.  All 750 wheels have a 6 bolt pattern for the brake rotors and 40 spokes. I think you have a CB350F or CB400F "baby four" front wheel. i would guess the fork spacing / hub is narrower on the 350 / 400 and thats whats causing your problems
Took some more pictures.
Checked the hub, bearings are good.
« Last Edit: June 07, 2015, 11:10:24 PM by Garage_guy_chris »
Offline jonda500
« Reply #26 on: June 08, 2015, 01:27:06 AM »
Well spotted garageguychris!
Wompom luckily it looks like you were wise enough not to - but just in case- don't do what I said to do with that wheel in there!
A starter clutch thread:
Offline Wompom
« Reply #27 on: June 10, 2015, 04:11:47 PM »
I cant believe that. It makes more sense that its just the wrong wheel. I was going insane. I guess its time to buy a new wheel.  :-\
Thank you guys for all your help!
