Author Topic: What's this green cable for? ...and..  (Read 1422 times)
Offline jebon
« on: June 09, 2015, 02:38:57 PM »
Does anyone know where I can get an original fuse holder and that other rubber cable thing that's worn out on this image?
"Don't let schooling interfere with your education"
CB750 K0 1971
Re: What's this green cable for? ...and..
« Reply #1 on: June 09, 2015, 02:44:09 PM »
Hondaman makes a replacement fuse holder.  www.SOHC4shop.com
isnt that an extra ground for a three-wire flasher?
« Last Edit: June 09, 2015, 02:45:55 PM by flybox1 »
Offline dusterdude
« Reply #2 on: June 09, 2015, 02:46:58 PM »
What year and bike,i may have one
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
DH
« Reply #3 on: June 09, 2015, 02:48:07 PM »
grn/yel = brakelight? or if its plain green, yeah, aux. ground.
« Last Edit: June 09, 2015, 02:53:12 PM by DH »
Offline jebon
« Reply #4 on: June 09, 2015, 02:48:49 PM »
1972 K2
CB750 K0 1971
Offline jebon
« Reply #5 on: June 09, 2015, 02:51:36 PM »
Brake light is fine. Sorry for not doing my homework before posting. The Button under the horn does nothing. Is that passing light/high beam?
CB750 K0 1971
« Reply #6 on: June 09, 2015, 02:52:11 PM »
yeah...just enlarged the pic.  green/yellow is brake light.
did you check both of your brake levers?
Offline jebon
« Reply #7 on: June 09, 2015, 02:54:43 PM »
Weird. I just had the bike inspected with no isues. Will check in the mørning. Thanks
CB750 K0 1971
Offline dusterdude
« Reply #8 on: June 09, 2015, 02:55:03 PM »
I have one off a k1,looks to be the same
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
DH
« Reply #9 on: June 09, 2015, 02:55:30 PM »
Maybe just dirt on wire. May be solid green? maybe verify for sure...
« Reply #10 on: June 09, 2015, 03:44:10 PM »
 Button under the horn button is the turn signal beep silencer. 72 bike?  You can use a blade fuse, cb750.com has a single fuse holder, on mine the rubber is so soft it won't hold the fuse properly so it just hangs there hardening while I use a blade fuse.
I think Honda has original fuse holders too. DSS, I'm sure too.
