Author Topic: F2 front discs  (Read 1041 times)
Offline teebee67
F2 front discs
« on: June 11, 2015, 03:35:37 AM »
Hi all - will front discs from an F2 go straight on a K series hub?
I'm only old on the outside.
« Last Edit: June 11, 2015, 04:53:12 AM by 70CB750 »
Offline underdog
Re: F2 front discs
« Reply #2 on: June 11, 2015, 06:11:27 AM »
 If you're looking for a lightweight bolt-on, a mid 90's Yamaha FZR600 works perfect. I only used one side, but I'd guess they'll work in duals also.
Re: F2 front discs
« Reply #3 on: June 11, 2015, 10:42:44 AM »
There are all several differences between those two (F2 and K discs). If a dual disc set up is your goal, the easiest way to accomplish it is to swap the entire front of a 1975-77 GL1000 (triples, forks, brakes, rotors).  You can also swap the entire front or selected portions of the F models.  Swapping the entire front ensures compatibility with offset (spacing/alignment of brake rotors and calipers) and avoids the needs for shimming.
Offline teebee67
Re: F2 front discs
« Reply #4 on: June 11, 2015, 12:40:16 PM »
Thanks all, I only asked as there is a pair on Ebay which have been drilled but I see they are no use to me now.
