Author Topic: 197? CB750F... The 'F' Stands For 'Found' In A 'Field'...  (Read 8636 times)
Offline DJKen
  • It's not what you ride, it's that you ride!
    • D.J. Ken's Mobile Music & Photobooth
« on: June 11, 2015, 08:43:06 PM »
My Son is collecting up the pieces of this bike he found while helping a friend clear some family property, I hope to ride home in a few months...
« Last Edit: June 21, 2015, 12:44:02 AM by DJKen »
Keep on Rockin',
DJKen
714-686-8397
Re: 1974 CB750F... The 'F' Stands For 'Found' In A 'Field'...
« Reply #1 on: June 11, 2015, 08:48:43 PM »
by the turn signals, and indicator dash that is not a '74...no F model in'74 anyway...'75 or later, hard to tell from pics whether it is F model or not
Offline DJKen
« Reply #2 on: June 11, 2015, 09:34:46 PM »
When he gets it all home, he can start finding all the markings... he was told it was a '74 so that's what we are going on til we actually get the bike in custody.
Keep on Rockin',
DJKen
714-686-8397
« Reply #3 on: June 11, 2015, 09:49:10 PM »
From the gauges I'm saying 75 F. Depends on the serial numbers. Wrong headlight ears. Engine has been out to install the chrome cover. Usually means goodies inside (possible).
Offline CycleRanger
  • No comment about being an
« Reply #4 on: June 11, 2015, 10:27:24 PM »
Hopefully not water... :o
Was it covered while in the field?
Offline DJKen
« Reply #5 on: June 11, 2015, 10:43:30 PM »
Only by weeds as far as I know... :p
Keep on Rockin',
DJKen
714-686-8397
« Reply #6 on: June 11, 2015, 11:59:51 PM »
Yep, no such thing as a 74 F model... ;)
Offline Restoration Fan
  • My wife will never call me
« Reply #7 on: June 12, 2015, 05:18:14 AM »
If the VIN plate is on the bike, you can find the year from that.  If the VIN plate is not on the bike, the VIN should be stamped in the left side of the steering stem and should also be on the horizontal cross member that connects the left & right sides under the seat.
The engine will also have a serial # stamped on it and don't worry that the 2 #'s aren't the same; they never are on these bikes because the frames and the engines were made at different factories and married together later.
Find the engine & frame serial #'s and post them on here and everyone will tell you what year your bike was made.  (You can actually find it out yourself on this site if you want to do so).
Regardless, welcome to the forum and good luck with the build.  Download the service manuals and parts lists for your bike from this site, print them out and use those as the starting point.  Take lots of photos, keep the build thread updated and post questions when you have them (note I didn't say if...you WILL have lots of questions).  But the good news is that there are guys on these forums who have done complete restorations several times and I can guarantee you that any question you have will be answered.  Good luck.  Look forward to following this one.
OH...and one more thing.  Take the time at night to find some complete restoration threads and read through those.  You'll be amazed at how much you will learn from reading through the threads of other builds.  A lot of the posters here will put their build threads in their signatures at the bottom of their posts, so just click on the links.
« Last Edit: June 12, 2015, 05:19:46 AM by Restoration Fan »
Offline Tews19
  • I am no
« Reply #8 on: June 12, 2015, 05:30:47 AM »
All the chrome and polished bits in that bike are awfully shiny and unfitted for being discarded in a field? Even the handlebars look to be unpitted. No debris on the rear inner fender either. Skeptical  ???
With ya. Never listen to PO! Also I think Cal has a great pic of a tree and a 500 together?
1970 Honda CB750 survivor.
Offline DJKen
« Reply #9 on: June 12, 2015, 08:55:19 AM »
Thanks Restoration Fan for the pointers, and to those who say it looks too good to be outside, do you honestly think we staged the photos with weeds growing up through them??? :p These are the first pics taken where he found the bike before he loaded it up...
I will post a pic of the numbers when he sends them and we can get to the bottom of what year it is soon after that, like I said; He was told it was a '74, (but the guy was obviously wrong).
Keep on Rockin',
DJKen
714-686-8397
« Reply #10 on: June 12, 2015, 10:09:58 AM »
FWIW, it could be that it's a K model instead of an F model.  If so, then it could very well be a 74.  The VIN # will tell you that.  The numbers on these bikes start with the model number...such as CB750K-xxxxxxxxx.
Offline DJKen
« Reply #11 on: June 12, 2015, 10:56:19 AM »
The number started with "CB750F-xxxxxx", I just neglected to write the numbers down when he called me about it.
Keep on Rockin',
DJKen
714-686-8397
« Reply #12 on: June 12, 2015, 12:11:03 PM »
The engine has definitely been out before, so as Jerry said, it may have some good stuff inside.  The oil tank looks like a 77-78 F or K model, which would be consistent with the F stamp on the frame.  The forks and the dash also appear to be from a 77-78 model of one kind or another.  My 750K2 had all kinds of different model parts on it so I am not surprised if yours has some from different models, either.  That said, it is definitely NOT a 1974 if it is a F frame bike.  Honda simply did not make the F until 1975, and the other bits seem to indicate it is likely a 77 or 78.
« Reply #13 on: June 12, 2015, 12:59:17 PM »
The good news if it is an F2 or F3 is that  those bikes had the most HP of any of the SOHC 750 stock engines, according to Bill Benton.  The head from that engine is very sought after by the guys trying to go big bore because the valves were larger.  At least that's what I was told.
« Reply #14 on: June 12, 2015, 01:33:38 PM »
There are pros and cons to the F2/F3 heads with reliability.
« Reply #15 on: June 12, 2015, 03:48:08 PM »
And the F/F1 head is more desirable than the early K's. It was used on the 77/78 K also.
Offline DJKen
Re: 197? CB750F... The 'F' Stands For 'Found' In A 'Field'...
« Reply #16 on: June 21, 2015, 12:46:35 AM »
Okay, so... He got it all collected up and brought home. He did find out that it had only been outside for about eight months and he took this pic, (it's not very good, I'll get him to take some better ones soon)
Keep on Rockin',
DJKen
714-686-8397
Wobbly
« Reply #17 on: June 21, 2015, 02:39:57 AM »
I agree. It's all slapped together. The instruments look like K7 to me--the F2 model has a higher red line. Pilot light and signals could be either K7 or F2. Wheels are Comstar type which would make them F2. Carbs are definitely pre 1977 which makes them K-Model up to K6 or F1 model. The headlight ears are probably aftermarket--nothing I recognize. The engine painted black doesn't mean a thing either. You just will have to look up the numbers.
« Reply #18 on: June 21, 2015, 09:05:15 AM »
Headlight ears aren't stock. 'Fork brace' thing is not stock. From what I see including the speedo and tach if they are original it is a 1975 F.
Offline DJKen
« Reply #19 on: June 21, 2015, 11:52:58 AM »
Thanks everybody for your evaluations of the photos, it's all going to help in the rebuild if we know where to look for certain things (instead of being locked into thinking it's all the same model year).
Keep on Rockin',
DJKen
714-686-8397
Wobbly
« Reply #20 on: June 22, 2015, 01:31:02 AM »
Before I bought my K7 back in 77, I had the F1. My memory might fail me, but I believe that the instruments were green not blue. That is why I think that these here match my K7.
« Reply #21 on: June 22, 2015, 11:19:34 AM »
You are correct Wobbly. The F1 had the light green faced instruments with the 8500 redline. The 75 F'0' had the dark green faced instruments with a 8500 redline.
Isn't this NOS instrument cluster a thing of beauty  ;)  Looks even better on the bike. The ignition switch has since been replaced with NOS too and the protective plastic on the panel has been removed. All individually pieced together. tell me this wasn't expensive to do  ;) :)
Also note no KPH ring on the speedo.
I'd REALLY love to go riding with you to some of your favorites!!
« Reply #22 on: June 22, 2015, 01:45:55 PM »
Cha-ching.  Nice!
Wobbly
« Reply #23 on: June 23, 2015, 11:27:23 AM »
Tell Me About It.
You'd have to come to Europe--and I show you motorcycle heaven. I live spacious and very nice (with compliments of the U.S. Army), and I can offer you an entire floor in the house to yourself and spot in my garage for the bike. And I know the most awesome places in the Alps. Seriously.
« Reply #24 on: June 23, 2015, 12:11:10 PM »
