Author Topic: RC Stroker crank  (Read 1017 times)
Offline teebee67
RC Stroker crank
« on: June 12, 2015, 12:04:18 pm »
I have a RC Eng big bore kit which has a stroked crank with shorter rods. I know the bore is 73mm can anyone tell me what the stroke is ?
I'm only old on the outside.
Offline Bill/BentON Racing
    • BentON Racing
Re: RC Stroker crank
« Reply #1 on: June 12, 2015, 12:28:21 pm »
1/4 inch usually.  ;D seen 7mm, got one! Not by RC though. Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #2 on: June 12, 2015, 12:41:25 pm »
Measure it Tony. If the motor is stripped down, just measure from the top of the block to the edge of the piston.
Sam. ;)
  • Moderator
« Reply #3 on: June 12, 2015, 01:16:37 pm »
Tony, if it's a 1160 motor like you said in the other thread and it has 73mm pistons, then the stroke should be 69.25mm to give 1159.5024cc, can anyone else confirm this ?
Sam. ;)
Offline teebee67
« Reply #4 on: June 12, 2015, 02:20:29 pm »
Not in a position to do that yet Sam, yes 69.25 will give 1159cc  with a 73mm bore. Your measurement method presumes the piston is dead flush with the top of the barrel at TDC. I got the 1160cc figure from someone on the forum but somebody else says 1180cc which would be 70.5mm.
How r u Sam - might be giving you a ring soon - need some info.
  • Moderator
« Reply #5 on: June 12, 2015, 03:13:08 pm »
Ring away Tony, I just dug out your number, was going to ring you then I noticed the time.
Sam. ;)
