Author Topic: 350 four carb sync lock tabs?  (Read 991 times)
Offline ripamarcone
« on: June 15, 2015, 03:25:33 AM »
Hi.
have a set of 350f carbs that Im rebuilding. noticed that the sync tabs ( i think thats what i might be able to call them ) are missing.
first of all would it still be possible to sync the carbs correctly without the tabs? and secondly , if not, is there anywhere I can source a couple of them.
has anyone got any idea of the size of the o-rings that are used on the connectors between the carbs?
thanks
Offline Bodi
Re: 350 four carb sync lock tabs?
« Reply #1 on: June 15, 2015, 03:51:12 AM »
These don't lock the sync or interfere with syncing. They eliminate the unlikely possibility of the lift arms coming off the main shaft ball ends.
Offline ripamarcone
« Reply #2 on: June 16, 2015, 06:04:54 AM »
thanks for your reply. will give it a go and hope nothing falls off.
Offline Bodi
« Reply #3 on: June 16, 2015, 09:12:17 AM »
They're pretty simple anyway - you could make them with a beer can, scissors, and a paper punch.
Offline riverfever
« Reply #4 on: June 16, 2015, 01:01:36 PM »
I made a set to replace both broken ones on my carbs.
Offline HondanutRider
« Reply #5 on: June 17, 2015, 05:12:24 AM »
The originals are a bit more substantial than what Bodi suggests.  I also made a replacement for one that had broken on a spare carb set, but I used some similar gauge of SS as the original that I happened to have around.  It was pretty simple to fabricate.  It seems to make the throttle openings more unified by keeping their linkage arms more in-line with each other.
Offline riverfever
« Reply #6 on: June 17, 2015, 04:57:04 PM »
Yes. I used some aluminum I had laying around and it's way overkill but it's what I had. I was able to find some of these from Holland I believe (via eBay) but the price was out of this world.
Offline ripamarcone
« Reply #7 on: June 20, 2015, 06:08:17 AM »
thanks for all your replies. I think i will have a go at making my own as well
