Author Topic: fender after fork swap  (Read 1592 times)
Offline aaron h
« on: June 16, 2015, 07:18:20 AM »
I bought my 72 750 with a 86 GSXR 750 fork.it did not come with the fender and I cannot find one that does not make it look like a street bike what can I use in its place?
Offline calj737
  • I refuse...
Re: fender after fork swap
« Reply #1 on: June 16, 2015, 07:45:49 AM »
About the best you can do, depending upon tire width, is to "bob" your stock fender, relocate the mounting struts to fit the Gsxr forks, and go that route. Else, you'll need a custom fender. This "fender issue" is the only downside to this swap in my opinion.
I don't like the look of the Gsxr fender on our bikes, and the stock is usually too narrow (120 tire) so a fiberglass or alloy custom is required. There are plenty of fender blanks available, you can then take some flat or round aluminum stock, heat it and shape it. Drill thru the fender and mount the strut over top from underneath the fender, and secure at the forks. Use 2 struts over the fender for a secure hold.
This is a stock front end, but the idea is the same:
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: June 16, 2015, 07:55:34 AM »
This is a common problem with modern fork upgrades. I went to great lengths to make a fender to fit the R6 forks on my bike. What do the mount points look like on GSXR forks. Can you post a pic?
Offline aaron h
« Reply #3 on: June 16, 2015, 08:27:12 AM »
I'll try to post some up
Offline aaron h
« Reply #4 on: June 16, 2015, 08:33:45 AM »
best I had while at work
Offline calj737
  • I refuse...
« Reply #5 on: June 16, 2015, 08:36:01 AM »
If you can get one later of the lower legs, side view, it will help identify some options. The upper bosses are useable for a brace, but not the best for fender mount.
Offline aaron h
« Reply #6 on: June 16, 2015, 09:20:45 AM »
Will work on that this evening
Offline aaron h
« Reply #7 on: June 17, 2015, 08:41:50 PM »
More pics
Offline calj737
  • I refuse...
« Reply #8 on: June 18, 2015, 03:28:59 AM »
It looks like you'll need to use the mounting holes above the tire, on each side. My GS500 uses the same fender mount/fork brace. You'll simply need to bob a fender or fashion one and install it from beneath that brace.
Here's a pic of the stock GS fender mount to better explain if you're not clear.
Offline aaron h
« Reply #9 on: June 18, 2015, 04:53:24 AM »
Ok thanks, I'll order a fender and make braces
« Last Edit: June 18, 2015, 10:05:53 PM by Retro Rocket »
Offline aaron h
« Reply #11 on: June 19, 2015, 03:58:35 AM »
Thanks ordered first link and brace! Only stock ones I had seen looked all funky.
« Reply #12 on: June 19, 2015, 04:56:20 AM »
The 88 and up 750 and 1100 GSXR front guards were bulkier than the early 750/1100 F,G,H model guards, I've owned both... ;)
Just remember those guards and braces in those links were to suit 18 inch wheels that the GSXR's had, the guard will fit but you may need small spacers {washersw} under the brace, you mightn't either but don't be too surprised if you do... ;)
Offline aaron h
« Reply #13 on: June 19, 2015, 05:03:54 AM »
Good tip, thanks. Hopefully it all works out, I have a 19" wheel on mine now .
