Author Topic: Pad Removal ?  (Read 977 times)
Offline rddcw
Pad Removal ?
« on: June 16, 2015, 01:41:10 PM »
Okay,  was able to loosen the caliper allen bolts with my Heat Gun just a few minutes ago and separating the caliper halves. Now I'm having problems removing one brake pad on the brake line/bleeder side of the caliper. Appears to be stuck ? Even trying to grip the pad with channel locks, it won't loosen or budge.
Soaking that caliper side with PB blaster. Any tricks removing that stuck pad before trying compressed air to blow out the piston?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Pad Removal ?
« Reply #1 on: June 16, 2015, 01:50:54 PM »
I have better results with hydraulic pressure as opposed to air pressure. Reconnect the master cylinder to the caliper and use it to pump the pad out. Some have used a grease gun on the bleed screw after opening, but that can get messy. If the MC needs rebuilt, then rebuild it and use it to pump the pad out.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Pad Removal ?
« Reply #2 on: June 16, 2015, 01:51:47 PM »
No offense intended, but this board is for complete PROJECTS, not on troubleshooting a portion of them.  You should post these topics on another board like SOHC4 Bikes.
Like the Global Moderator says:
http://forums.sohc4.net/index.php/topic,58514.0.html
Offline rddcw
Re: Pad Removal ?
« Reply #3 on: June 16, 2015, 04:36:05 PM »
Pad and Piston Removed ! Use the Grease Method. Thanks So Much Again, for All the Advice !!!
P.S.  CB750 Cafe Racer Fan,  I'll be sure to use SOHC4 Bikes Forum next time. :) :) :)
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: Pad Removal ?
« Reply #4 on: June 16, 2015, 07:54:35 PM »
Glad you got it removed.
As madmtnmotors has said, you can mock up the MC and bleed the piston out...
Carpy's advice (especially the video at the bottom) helped me immensely:
http://www.cb750cafe.com/blog/how-to-remove-piston-from-front-caliper-on-cb750k/
