Author Topic: Gas Leak  (Read 3788 times)
kmenzel
Gas Leak
« on: April 03, 2005, 06:14:40 AM »
I recently picked up a 1974 cb750, bike is in very good condition, starts easily and after it warms up for a few minutes idles very nicely.  However, i have noticed after I shut it down within five minutes a get a pool of gas below the bike.  Any ideas what would cause leak.  ??
Offline cben750f0
Re: Gas Leak
« Reply #1 on: April 03, 2005, 06:26:33 AM »
yeah either have a leaking needle and seat, in which case turn your fuel off, and remove the carb bowl,floats, and needle and seat, and give them clean, or you might need to rebuild your carbs.... a problem i had was that the float bowl gasket was perished, and would leak past the top of the bowel.... but again i also had leaking needle and seats.... hope this helped..cheers
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Gas Leak
« Reply #2 on: April 03, 2005, 06:47:26 AM »
Don`t forget to check your oil for gas contamination.If the needles and seats are leaking then chances are you have gas in your oil now.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline cben750f0
Re: Gas Leak
« Reply #3 on: April 03, 2005, 06:54:56 AM »
   i agree hole heartedly on that one... if you know its been leaking, and you havent started the bike... you can get away with just daining the sump... but if you start it... you will have to replace all the oil.....fix the carbs, and change the oil.....peace
Offline Bob Wessner
  • "Carbs Suck!"
Re: Gas Leak
« Reply #4 on: April 03, 2005, 10:16:59 AM »
Do you routinely shut-off the petcock? Does the pool of fuel below the bike continue to get larger, or does it just stop at some point?
kmenzel
Re: Gas Leak
« Reply #5 on: April 05, 2005, 08:01:32 PM »
thanks for the help, im sure the carbs probably need to cleaned.  Also, i think i left the gas on the one night.  It was never a huge pool.
