Author Topic: hondaman ignition install  (Read 1282 times)
Offline b5rider
« on: June 22, 2015, 06:28:03 AM »
can anyone post some pictures of how to install a Hondaman ignition on a 550? I have a custom wired starter switch and a new rectifier/regulator combo and was wondering where to find all the wires used during the install.
thanks
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline RevDoc
Re: hondaman ignition install
« Reply #2 on: June 22, 2015, 11:58:36 AM »
Hi, B5! I found the wiring diagram Mark sent with the unit I got for my '78 550 very easy to follow. There wasn't one with yours?! Install was a breeze and what an improvement in the response! The link on the page that Flybox sent you has the same diagram.
BTW, if you are running with the airbox, rather than trying to position the controller behind the batt. housing or on the frame somewhere, I just put it in the tool-tray with Velcro on the back of the controller. Ran the wires over the back of the tray and down between the frame and rear fender. Simple feed forward along the main harness after that. Piece of cake. :D
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline b5rider
« Reply #3 on: June 22, 2015, 12:38:23 PM »
Thanks Rev Doc.  I haven't purchased it yet. My bike is  built with a custom starter switch (basically no right-hand controls,  just a button on the dash to actuate the starter) so I. Was worried I would not be able to trace/match the new wiring
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
