Author Topic: HElP!!!!Honda cb 500 four latching gearshift drum  (Read 616 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: June 24, 2015, 01:56:51 PM »
So i just put my crankcases together and every think was okay in the inside nothing was broken or worn. But i got one problem
so i put cordless thrill on to other gearbox shaft and i turned it around fast with thethrill (so i can see does it work like it should)
and i turned gearbox and sometimes the gear dont go all in when i turned it aroud with the thrill and then if i dont get gear back on it right position my gearshift drum latch and i have to open gearshift drums bolt on the upper crank case and then it works again. And this latching happen from second gear to 3 or to 4.and when i try to put gears when i turn gearbox with hand it doesnt never latch!
So whats wrong?
Re: HElP!!!!Honda cb 500 four latching gearshift drum
« Reply #1 on: June 24, 2015, 02:11:51 PM »
try it again while turning the front sprocket shaft.
small rotations forward and back to help the shift forks get the dogs lined up.
