Author Topic: A BIG thanks for the 77-78 750 carb help  (Read 3172 times)
Offline scondon
  • Mmmm......tasty bugs
« on: October 22, 2006, 01:12:36 PM »
 Just wanted to say thanks to all who posted to the "Air fuel ratio 836 engine" and "Yet ANOTHER dyno result" threads in regards to tuning my carbs. All the info you guys gave was very helpful in diagnosing troubles I was having with the idle circuit and transition between idle and 1/4 throttle.
   I pulled the carbs off yesterday for what I hope is the last time for some years to come :) Here's what helped.....
 When measuring fuel heights initially, I found that the fuel level was 1/2" below float bowl gasket. When I pulled the carbs and remeasured the floats they were measuring at the suggested 14.5mm with the lowest one measuring at 15mm at the front(still within +/- .5mm spec. Put the carbs in a vice and, using a clear line to measure fuel levels, bent each float "tang" until the fuel height reached 1/8" below each float bowl gasket. Remeasured the floats at this point and found that the rear of the floats were still at 14.5mm but the fronts were at 13.5mm( for those not familiar with 77-78 floats they are flat on the bottom, not round like earlier carbs ).
 While the carbs were in the vise I swapped the float needle in my #1 carb since it didn't seat properly and would overflow if fuel tap was left on. I had a pack of 4 aftermarket float needles and tried a couple different ones until I found one that actually shut off the fuel. Damn aftermarket float needles! They seem to be "hit or miss" :P
 I checked the operation of the accelerator pump(thanks eurban) and found that the outer fuel pipes(#1,#4) weren't pumping as much as the inner two(#2,#3). On closer examination I saw gas leaking out of the back of #2 float bowl where the accelerator pump attaches to the carb body. The small rubber accel pump o-ring that fits in between the float bowl and carb body was no longer up to the task. Replaced it and now each carb gets equal geyser of gas when the throttle is twisted :)
  With carb cleaner and compressed air I checked that all four slow jets were clear and that the air jets(airbox side) and small fuel delivery holes(engine side) were clear and doing their jobs. Set the fuel idle screws at 2 turns out, buttoned up the carbs and put them back on the bike.
   I've now got carbs that don't leak when the petcock is left on overnight. Engine accerates very well when I "roll" on the throttle. And it idles very well (and very quietly) at 900rpm :)
  I've still got to dial in each idle screw for maximum performance. Averaging 2 1/2 turns at the moment. And I may fiddle with the accel pump arm gap to fine tune the transition between idle and 1/8 throttle. Also, I'll probably take out the last "shim" washer beneath each jet needle to lean out the midrange. Since the accel pump is working so well now the mixture becomes VERY rich when the throttle is "snapped" open and there is some hesitation in the acceleration while the motor catches up, hope the needle drop will limit this effect. All that aside, the carbs are functioning very well for daily riding and the test ride through the twisties this morning put a big, fat grin on my face ;D
  Thanks again, fellas. You ROCK!
Re: A BIG thanks for the 77-78 750 carb help
« Reply #1 on: October 22, 2006, 01:18:20 PM »
Sean
 My buddy dropped off your rods today. I think I'll post some pics on the forum if you don't mind.
Offline scondon
« Reply #2 on: October 22, 2006, 01:35:49 PM »
Sean
   That would be great,Mike :) I'm still waiting on the crank, but when it comes in I'll add some pics of it along with that sweeeeeet cylinder head you put together for me.
« Reply #3 on: October 22, 2006, 02:43:49 PM »
Sean,
Now that the carb dilemma is over you gotta tell evryone about your crank work and the $$ damage that cost.
Mike,
I gotta see the rods and find out what you've had done.
Offline scondon
« Reply #4 on: October 22, 2006, 03:11:39 PM »
Sean,
Mike,
 Just to clarify, all the crank,rod,head work is going into the next bike. Current bike ( the one that got the dyno run and carb help ) has a stock, unmolested F2 bottom end.
   Nothing super special being done to the crank. I sent it down to A.P.E. to be balanced and lightened. I have no idea whether the engine will benefit greatly from having this done, but I am the "curious" type and would like to compare the new engine to the one I'm running now. Cost of admission is $225 plus 2-way shipping.
   As far as the rods go, I asked Mike to wave his magic wand over my stock F2 rods and give them his blessing :D   I'll let him answer any ?'s about them since I really am a "noob" when it comes to this stuff.
Offline eurban
« Reply #5 on: October 22, 2006, 03:51:34 PM »
Glad to hear that your carbs are working better.  It would be interesting to see what the dyno's AF meter comes up with now. . . . . .One interesting thing about the 77/78 carbs is that the float height spec for the 77K model is 12mm.  I have a number of sets of these carbs from K to F alike and other than the numbers's stamped on the bodies I haven't been able to discern any real differences.  According to the specs in the Honda manual the Fs have different size air jets(s) but I haven't figured out a good way to measure this.  Anyways, setting your float heights closer to the12mm spec should be fine.  Enjoy!
Offline scondon
« Reply #6 on: October 22, 2006, 04:42:19 PM »
   Makes sense, with all the advice/info you provided, that you would have extensive experience with these later carbs. :)
   I am curious which carb set (K or F) you are running now. All I've got for info is the '78 750K/F Honda manual. It shows the K as having 110 mains- 1 1/2 turns on the pilot screws vs 105 mains- 1 3/4 turns for the F. Float heights for both are stated at 14.5mm so I wonder what's different about the '77 carbs that they would be set at 12mm.
   I'm sure that the '78 750F head design(larger intake valves, larger combustion area, domed pistons, slightly lower combustion ratio) would have some effect on how the carbs are set-up. Since I'm running a K8 head I wonder if the K series carbs would be a better choice if I'm going to stick with the stock carbs. I'm guessing that the air jets on the K carbs are bigger, yes?
   Of course, that's all just food for thought as I am about to the point of calling it "good enough" and switching my attention back to the new bike project :)
Offline IndianRider
« Reply #7 on: December 21, 2006, 05:41:49 AM »
buddy .. can u explain waht accel pump 0-ring you are talking about that sits beteen the float bowl and the carb body ? ..  i opened mine yesterday and i only had the usual carb bowl rubber gasket on carb # 2 and did not see an o-ring .. is there 2 rubber gaskets that go between the carb body and bowl on carb # 2 .. ??  unless ur not talking about the springy rubber thing that goes around the acc. pump shaft ..
« Last Edit: December 21, 2006, 05:45:01 AM by IndianRider »
Offline scondon
« Reply #8 on: December 21, 2006, 09:43:30 AM »
  From your response in Accelerator Pump No Worky....
"then i sprayed carb cleaner into the tiny hole in the upper body of carb # 2 that supplies the fuel spray to all 4 carbs"
    There is a corresponding "tiny hole" in the #2 float bowl. There is a slight,circular depression around that hole for a small o-ring to sit in
Offline IndianRider
« Reply #9 on: December 21, 2006, 10:33:17 AM »
awesome ... thats where the problem is .. when i opened my carbs first time 2 weeks ago, the corresponding hole in the # 2 float bowl did not have that small 0-ring .. that i thought was pretty strange ..  ill need to get that ordered to seal up the acc. pump circuit ... thants a lot ... cheers ...
Offline IndianRider
« Reply #10 on: December 21, 2006, 10:51:47 AM »
just cannot find that small 0-ring for bowl # 2 in the honda parts fiche .. can anyone help with a part # please ?? thanks ..
Offline scondon
« Reply #11 on: December 21, 2006, 11:11:49 AM »
 I'll see if I can find the # when I get home tonight.
Offline dusterdude
« Reply #12 on: December 21, 2006, 11:48:31 AM »
sean,are you going to have the whole rotating assembly balanced also,if so who is going to do it?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline scondon
« Reply #13 on: December 21, 2006, 12:15:13 PM »
   Took me a second to think about where the rotating assembly was in the carbs :D
    You're talking about the crank, rods and rotor though, right Duster? In that case the answer is no( I wouldn't know where to take it or what the extra expense might be ). The rods have been hardened and polished and lightened so they are all of equal weight. The crank has been lightened and balanced and the stock rotor put back on. The whole assembly is already buttoned up in the cases and I am only waiting on the "King of Procrastinators" to finish boring my cylinders so I can finish the motor.
Offline scondon
« Reply #14 on: December 21, 2006, 03:21:25 PM »
   Your right, it doesn't appear seperately on the part fiche :P  You can see it as part of the #2 float bowl and accel pump drawing here...
http://www.cmsnl.com/honda-cb750f-750-super-sport-78-us_model7240/partslist/E++2001.html
it has a #1 next to it which implies it is part of this packing set..
http://www.cmsnl.com/products/packing-set_16010405004/
   It's far cheaper to get a small assortment of 0-rings from the automotive or hardware store and just use one that fits in the recess. They're easy to forget about and lose so nice to have some extra's on hand.
Offline mick750F
« Reply #15 on: December 21, 2006, 04:12:55 PM »
   I should have one of those o-rings as they are included in the Honda carb kits. When you buy 4 carb kits you end up with 3 extra. It might take me a couple of days to dig it out but if I can find one you're welcome to it.
Mike
Glosta, MA
Offline IndianRider
« Reply #16 on: December 22, 2006, 05:44:45 AM »
thanks mike .. i would appreciate it if u can send one my way ... please let me know when u find it so i can pm you my addy .. thanks ..cheers ..
Offline IndianRider
« Reply #17 on: December 22, 2006, 05:49:32 AM »
thanks scondon .. it is shown in the diagram you linked to .. hope mike can find one otherwise ill hit the hardware store again ..
Last week, I got these 0-rings at Lowe's ($1.50 for 10 or 15)  for the carb drain screws and although they were a bit tight to screw in the first time even with motor oil lubrication, they fit real well and tight ..
Offline IndianRider
« Reply #18 on: December 22, 2006, 05:51:29 AM »
i got some extra O-rings for the air/fuel screw from www.crc2onlinecatalog.com and im thinking the size might be similar ..
Offline mick750F
« Reply #19 on: December 22, 2006, 02:32:54 PM »
   I should be spending some time in my shop tomorrow so I'll see if I can dig it out.
Mike
Glosta, MA
