Author Topic: engine rebuild question  (Read 738 times)
Offline KirkBurner
« on: June 29, 2015, 11:12:32 AM »
I am rebuilding a cb750 k-3 engine.
The crank shaft was turning ok.
I put the head on, and suddenly everything was stuck.
Removed the head and it was turning freely again, anyone got any tips?
Re: engine rebuild question
« Reply #1 on: June 29, 2015, 01:06:19 PM »
So the pistons move in the cylinders freely? Spark plugs removed so no compression? Cam installed? Rockers all loose? Is it stuck with the cam installed? If so check that your cam isn't out 180 degrees perhaps and a valve hitting a piston. Cam chain binding?
Not really enough info.
I'm putting mine together as we speak but realized I didn't order a slotted sprocket so I came in to do that and saw your post.
Offline 01Thomas
« Reply #2 on: June 29, 2015, 02:22:11 PM »
I've had this happen with a Kawa GPz1100 engine I was rebuilding. In that instance the engine had been resleeved to take a big-bore kit - and two of the sleeves were long enough to contact the crankshafts' counterweights when the head was torqued down.
Is your camchain not bunching up somewhere/somehow when you put the head down?
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline KirkBurner
« Reply #3 on: June 29, 2015, 10:13:11 PM »
I check the ring gaps before installing.
I didnt have the the rockers installed, so no cam.. had a loose camchain
no compression as I pulled all the sparkplugs.
I just found this really wierd, so I thought Id ask around if someone else had experienced this.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #4 on: June 30, 2015, 02:38:47 AM »
Do you have the correct head gasket for the size bore that you have? The pistons maybe fouling on the gasket fire ring when you tighten the head. As Jerry mentioned - not enough information. Pat
Regards
Pat from Australia
