Author Topic: broken teeth of crankshaft  (Read 6897 times)
Offline Aurel
Re: broken teeth of crankshaft
« Reply #50 on: July 04, 2015, 01:59:24 PM »
I didn´t buy the chain from classic cycle city i bought it from bike side. It lokks like the same the classic cycle city sell. When i make the photo i saw that 3 or 4 links are really have to move. I think the chain where damaged then the teeth are breaking.
« Reply #51 on: July 05, 2015, 09:34:20 AM »
Are the chains opened and riveted again? I think about offset link mentioned earlier.
The chain shape reminds me about my latest drive chain and first attempts to rivet solid links. I had to remove master link an do it again with a new link when I did it too hard first time. Chain got a Z shape.
Offline Aurel
« Reply #52 on: July 05, 2015, 09:42:44 AM »
No the chain was closed when i bought it .
Offline kmb69
« Reply #53 on: July 05, 2015, 10:04:10 AM »
PeWe, I don't think the mentioned offset link that you are picturing is what they meant. They meant alternating the inside and outside links between the two chains.
Couple of pictures here: http://forums.sohc4.net/index.php/topic,79183.msg1492407.html#msg1492407
Scroll down to see the difference.
« Reply #54 on: July 05, 2015, 11:26:54 AM »
AHA! OK NOW I'm with you. Thank you very much! Not more complicated than that...:) hmmmmm......alzheimers  ???
I do not recall how I did my latest chains, also heavy duty ones. Old primary chains were both mounted same before according to my old photos. I guess that is natural for me if not thinking about it.
I'll open my case coming winter.. I'm curious how it will look like.  Very strange that I did not investigate the primary chains before.
Offline kmb69
« Reply #55 on: July 07, 2015, 07:45:32 PM »
Honda outside, Keith inside. Get to work sucka.
I am shocked!  :o  NOT!  :o  The deposits are not, I said "not", just pouring in.
As I suspected, you can buy a lot of primary chains for what one of these gear drive systems would cost.   :) ;) 8)
WANTED   -   WANTED   -   WANTED
Does anybody have any pictures other than the one in this post of the primary internals of these Honda endurance engines?
I sure would like to see how they secured that gear to take the beating in the bottom case.
Find it kind of interesting that Honda went with the Hyvo chain in the DOHC's after using the gear in their protos.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #56 on: July 07, 2015, 07:51:36 PM »
I'll check with Rob/Voxonda,  he'll know, Bill  ;D
BentON Racing Website
BentON Racing Facebook
« Reply #57 on: July 08, 2015, 05:48:25 AM »
Because chains are cheaper than gears. ;D ;D ;D
Offline Aurel
« Reply #58 on: July 08, 2015, 12:33:04 PM »
There is a bigger problem with the gear between the crank and the primary. you change the rotation direction of the  final  drive shaft. the only way you can handle this problem you use a camshaft with a revers rotation and did´t use the kick starter. When i have time i will look that's a good project for the future. i have a guy how makes gearshaft and gears that's not the problem i have also a solution to set the proper  teeth clearance. It´s a really expensive project but i will look to find a solution to realize the geardrive. Did somebody have 3D modells of the engine that would help a lot.
Offline turboguzzi
« Reply #59 on: July 08, 2015, 01:07:15 PM »
mmm..... just a second, before you jump into the CAD ;)
no problem whatsoever with the RSC kit, idler gear rotates backwards, then final shaft rotates fwd again, just like with a chain :)
nice try ::)
Offline Aurel
« Reply #60 on: July 08, 2015, 01:41:44 PM »
Sorry that was a mistake with the rotation direction.
When i have a extra gear i didn´t change the rotation. my first idea was to use two bigger gears without an extra gear in the middle then i have the problem with the direction. Sorry it was inprudent. :-)
« Reply #61 on: July 28, 2015, 06:46:35 PM »
Pictures coming, not sure when but they are coming... ;)
Offline kmb69
« Reply #62 on: July 28, 2015, 08:22:56 PM »
Awesome, RR  ;D
« Reply #63 on: September 20, 2015, 04:36:07 AM »
Any final root cause of the broken teeth?
-Was the primary hub involved? EDIT: The new rubbers were std or or harder?
I searched and found this old thread about hub restore/upgrade, if not chains might break. I guess with stronger chains, the cogs will be next to get problem.
http://forums.sohc4.net/index.php/topic,65107.msg714659.html#msg714659
I'm thinking about my prim hub that has over 100.000km's, sound at idle like it need to be restored, upgraded. My engine has 80+ RWHP
« Last Edit: September 22, 2015, 03:35:02 AM by PeWe »
